I am making program in version 2010 in which I can select maximum 3 reference Datum as a 1st segment in datum feature frame. I am seeing condition of True position in drawing which has total 4 reference Datum as only 1st segment. Could someone tell me how it would have been done.
Total four reference Datum in True position
1. True position = 0.2mm. with reference to datum A,B,C,D. at 113.13 mm.
2. True position = 0.2 mm. with reference to datum A,B,C,D. at 295.53 mm.
It doesn't look right. Can't really tell too much because the image is still blurry. But it looks like Datum A is a front surface? (Can't tell since it's cut off). Datums B and C look parallel to each other, and Datum D is perpendicular to Datums B and C. Looks like the callout should be 0.2 | A | B-C | D. Possibly a print error...
- 1 like
Illegal call-out.
Print is not clear (large enough) but this is my understanding of it.
You have Position of the edge (illegal, position can only be used for feature of size) to Datums A (top surface in Z+), B (edge of the part), C (edge of the part parallel to datum B, illegal) and D (edge of the slot perpendicular to B and C)
Who ever made this print does not understand GD&T, you should talk to designer and ask him to correct it.sigpic...engineering
Originally posted by Jignesh View Post[ATTACH=CONFIG]11636[/ATTACH]
You can decipher the latest uploaded drawing now. The edge of slot is considered Datum-D. Datum-A is top surface with flatness tolerance.
Originally posted by Josh Carpenter View PostI looks like B & C might be datum target points - so a Line constructed between them would be a new single datum named BC (don't use the dash in PC-DMIS).sigpic...engineering
I called my software company which makes programs in CAD. The engineer told me to take Mid line of Datum B and Datum C and consider one Datum for both Datums. He is right because I told him that I saw another drawing that has slots on both side of center line and both slots are considered Datum-B. So in this case I had to find center line of both slots individually and then I defined center line of both center lines which I considered as Datum B. But in above situation, there are two Datums given so it was little confusing how to adjust Datum in Datum feature frame. So I would have to consider Mid line of Datum B and Datum C for Example Datum BC. So True position will be 0.2 mm. with reference to Datum - A,BC,D. Thanks for being intrested in my question.Last edited by Jignesh; 04-19-2016, 09:24 AM.
Who ever is making these drawings for you does not understand GD&T. Even if you use this made up line for secondary datum, you can't have Position of edge of the part. Position can be used only with features of sizesigpic...engineering
by Berto
I've presented this to three people and have gotten three different answers.
I'm trying to figure out the true position of Datum...-
03-14-2014, 01:32 PM -
by Onehot82hello all. i am having an issue dimensioning true position. the dimension calls for true position .010" max material condition to datum -h-/ datum...
12-18-2012, 03:32 PM -
by Jonathan SIf you were to report a true position for a hole in 2 axes using another hole as a datum, shouldn't the calculated deviation be the same if you align...
03-20-2006, 05:33 PM -
by zoolander303Using the new version and I have a strange red flag to me at least with my secondary datum deviation. Primary datum is a Cylinder in Xplus work plane,...
11-15-2020, 07:59 PM -
by qcfire65
Need a little help construction true position within A for datum B....-
03-30-2016, 10:23 AM -
