trying to use a 3BY40MM with an extended force module and a 50mm extention - i keep getting a deflection error. anyone know if there are there any adjustments that can be made so its not so sensitive?
PH9A - deflection error
I keep getting a movement interupted error on 2 different machines. Probe is not hitting anything, can anyone tell me what might be going on?
12-13-2012, 02:02 PM -
by RookieI'm trying to calibrate a new probe on an LSPX3 (Leitz) head. I go in to measure (MAN+DCC).
I get an error I've never seen before:...-
10-19-2013, 02:55 PM -
by Mike_BIm trying to calibrate a "T" shaped probe, EXT force TP-20,ext20mm, ext30mm,ext30mm, then the 5 star adapter, but im using only 2 sides, one...
06-19-2013, 05:42 PM -
by OctopussjumpHey all... the battle for a new tp-20 module has finally come to a breaking point - literally.
The same old Renishaw STD force tp-20 that's...-
07-19-2007, 10:14 AM -
by ag1979Has anyone used, or does anyone use a gram gauge to set the proper triggering speed. And does anyone know a good way to figure out the optimum trigger...
04-21-2006, 11:25 AM -
