Does anyone know what file extension you have to rename in order to open an existing program offline so I don't have to turn on the controller. Thanks in advance.
Programming offline
Originally posted by Randy L.Does anyone know what file extension you have to rename in order to open an existing program offline so I don't have to turn on the controller. Thanks in advance.
prior to 3.6 only it is interfac.dll
rename temporary to .000dll
or whatever you like then change it back
this has been posted before and is not B&S approvedsigpiccall me "Plum Crazy"....but you only go around once!
Originally posted by Dick HelmI don't understand why not just pull down the interface tab and select offline?
please elaborate...
I am using 3.5 mr2 and don't recall the interface tab you speak of
thanks
Mikesigpiccall me "Plum Crazy"....but you only go around once!
Originally posted by Dick HelmYeah, it is File\Open then pull down on interface block
got it here too in 3.5 mr2..........I fogot about that one
I do believe that this might be a "enabled" option in the dongle
where as if you don't have it the previously mentioned option is the way to go...or so i'm told
thankssigpiccall me "Plum Crazy"....but you only go around once!
The origional posting was what he had to rename so that he didn't have to turn on the controller and home the machine. Maybe they have the air off, or he is planning on being there when the air is off and he still needs to get into Pcdmis. The the machine CAN'T run, then turning on the controller does no good, so he wants to know HOW he can run Pcdmis with the controller OFF. PRE V3.6, you rename teh INTERFAC.DLL file to anything else (I usually do with INTERFAC.CLL), then when you open Pcdmis, it will behave like it is offline. This only works PRE V3.6, but I am not sure how far back it will work.sigpic
Originally posted by Thomas PhillipsIn 3.7 MR3 when the controller is off and I try 'open' nothing happens.
If I start a 'new' program I am in but can not open an existing program.
whats with that!
Thomas (short on air)
That is a fix applied by big brother so we pay for "offline"
I believe that you could create a new and save it to be opened later when the machine is "online"
give it a try
It works like that in 4.0 alsosigpiccall me "Plum Crazy"....but you only go around once!
by bigblockv8I am wanting to use a seperate computer for offline programming. Does anyone know the requirements on how to do this. Will I need to buy a new software...
11-20-2012, 11:05 AM -
by DeWain HodgeI get interupted a lot to check production parts while programming offline and we only have one seat for PC-DMIS. Once I exit the program I'm working...
05-12-2008, 04:28 PM -
by teamjnzHello,
I am a brand new PC-DMIS userI have installed the software at my workstation that is not connected to the CMM. I was told...
07-28-2011, 07:04 PM -
by gcaudilldoes anyone know how to program offline on a computer that is hooked up to a cmm? I started the program on an offline computer but we have two programmers...
01-15-2014, 09:33 AM -
by TCeckelsHey guys,
The key phrase around here for this month is "Off-line Programming" and although I think I have a good grip on the...-
07-22-2008, 10:43 AM -
