I took one point in 5mm. slot. The touch speed is 2% and scan speed is 10% and both are default. I did not change speeds. Would it be better to change touch speed lower and I am not sure about scan speed. In fact, I reduced prehit and retract values for the point.
Touch speed and scan speed
scan speed is NOT the same as touch speed.
touch speed is for single touches, where the probe is moving normal to the surface, then into the surface to make contact.
scan speed is a lateral speed, the speed at which the scanning head/probe will move over the surface collecting data.
They are (basically) 90 degrees to each other.sigpic
Originally posted by Jignesh View PostI took one point in 5mm. slot. The touch speed is 2% and scan speed is 10% and both are default. I did not change speeds. Would it be better to change touch speed lower and I am not sure about scan speed. In fact, I reduced prehit and retract values for the point.
Do you even have an Analog scanning probe?
If you are taking hits, the TOUCHSPEED in the part program must be set exactly the same as the TOUCHSPEED used during probe calibration.
Do not slow it down, even for tight work with small prehit-retract clearances.
If you are scanning, the above is still mandatory - but then you also use SCANSPEED vary the speed of the Analog scanning probe dragging across the part surface and as it collects contour data.
Originally posted by Matthew D. Hoedeman View Postscan speed is NOT the same as touch speed.
Furthermore, it is highly recommended that for Analog full-contact scanning you switch the program mode from Percentages to Absolute Speed.
In the F5 tab Part/Machine, you would check the box for Display Absolute Speeds. The number shown there is the max speed limit of your machine.
Note that:
A) This is a global setting for the entire program, and
B) It is always in mm/s (millimeters per second) even in inch programs.
Once you switch it, click the Defaults button to set the Absolute Speeds mode as default so that all new programs use that mode.
Then, all MOVESPEED, TOUCHSPEED, and SCANSPEED commands need to written to a flat mm/s and not a percentage of machine maximum.
by Master ChiefHave a question with touch speed. If I slow down my touch speed in the middle of a program (to measure a couple of fairly small holes) would this affect...
02-04-2009, 11:44 AM -
by BKulpaI have a program for a tight tolerance part that I want to scan portions slowly, then speed the scans up for other portions.
No matter what scan...-
07-30-2019, 03:51 PM -
by TommyArrowUm... I have spent 15 minutes trying to find this answer on the forums... It seems like a stupid question but.....
In my f5 settings, the...-
12-06-2013, 10:07 AM -
by ADAM WALLACEI have a program running at 75 percent move speed. I need to slow the move speed down from the 75 because of false triggers moving in the z axis of the...
10-24-2013, 10:23 AM -
by 1CMM4MEYea, I know it's somewhere in the threads, but I have looked for an hour and have not found what people generally run their machines at and their touch...
09-09-2008, 08:24 PM -
