The one is made of a Granite Epoxy material. You will need to consult the literature for the one machine for the allowed weight. There is usually two weights, a weight that is called out to maintain spec and then a max weight.
Quick question, is there a way to program so my PH9 will index while doing the needed move points to get to the next feature to be inspected or does it...
I have constructed an array of 20 points. then assigned 2 seperate variables Max variable and Min no problems. I then report that using a generic feature...
