Measuring round slot w/different radii?
  • Measuring round slot w/different radii?
    one end is bigger than the other...still a round slot but any way to report each end?
    TIA!
    sigpicDF
    The "NEW AND IMPROVED" Golden Rule!
    You are looking to report the radius of each end? Why not just measure them as seperate features?
      Say WHAT? Are the sides of the slot parallel? If they are NOT, then you can not use round slot, if they are, then you still shouldn't use round slot since a round slot, by Pcdmis definition, has identical radii at each end. What you COULD do is use square slot for center (using WIDTH MEAS) and then 2 circles, one for each end.
        ok...I figured as much. Thanks guys...I'll measure it separately and report as such. Just thought you GU-RUS might have a work around!
        sigpicDF
