Profile a radius using autocircle
  • Profile a radius using autocircle
    Hi everyone,
    I'm checking a radius using autocircle off of cad. It locationally dimensions fine, but it won't do a line or surface profile. Do I have to take single points only to profile this radius or is there a secret to this with PCDMIS I don't know
    A circle is a single entity. You could do ROUNDNESS to see how 'bad' the surface is. IF that is not good enough, you will have to do it as points, either as a scan, or single points, make a set, and do the profile OR do single points then dimension each one using 'T'.
      Are you using V4.1? XactMeasure GD&T? Do you have datums to refer to?
      I found that V4.1 does not like profile tolerances without any datum references. I am not sure whether that is even correct. You can have a profile call without any datums as second line on a composite. But I am not sure that you can do that as a regular call too.
      Jan.
        Jan.
        Yes you can have profiile without regard to a datum but the feature should have basic size. For example, profile of a radius. Form is a "cheater" method because it has no relationship to size. The software would have to allow bestfitting of the basic form in translation and rotation.
        "Cheater" as in - not having the right tools.
          I am using 3.7 MR3. I wish I could use autocircle to do this though. Hopefully in the future they will have a option to make your autocircle points single entities so that you can profile them also and dimension them locationally off of the same feature. Thanks everyone for your help.
            Thanks. Learned something today...
            Jan.
            • hertangel
              Profiles
              by hertangel
              Can some one help me with a few profiles ?
              I have a profile of a radius, profile of incline line (angle) and profile of a circle.
              How would...
              04-03-2012, 10:55 AM
            • hitalov
              Using profile of a surface
              by hitalov
              I have a part that has a 2.5 radius call out on a really small area, it is almost imposible to get an acurate reading,
              what i did is measure a...
              04-17-2015, 12:43 PM
            • AuRules
              Profile
              by AuRules
              The attached print shows a hole that we cut into the top of one of our parts. The blue prints shows the hole with a few inside and radius dimensions and...
              08-06-2009, 07:06 AM
            • Liambo734
              Profile Tolerance
              by Liambo734
              The R45 pad feature (file attached) is raised up 2mm from the backface, around this pad is a 3mm rad +/-1mm which is not a basic dimension. I can measure...
              05-25-2012, 08:06 AM
            • amosl@mushield.com
              Help with profile
              by [email protected]
              I attached a print and need help measuring the radius and the profile of this feature....
              02-09-2015, 11:38 AM
