I have currently got 5 tools in the libary for use when calibrating the probes.I am trying to add another one,but every time i go out and come back in to calibrate it has disappeared.Can you only have aset amount of tools in the libary? i have also tried to edit a current one with new details but when i go back in the original ones are still in the area.?
Adding reference sphere
please help
The drop down box only shows 5 tools and there is no scroll down facility. We are using the calibrate/edit probe, probe utilities box then opens select measure icon, a new box measure probe opens allowing you to change the tool you whish to use / edit / delete (is there any other places the tool data may be stored).
Any thing you do here is lost when you exit the software fully.
Phil
Hi BJ
I am also curious about the 5 tools described in your qualification window.
I have 2 different tools one for dual ball artifact and one for single ball artifact.
KevinB & S XCEL 7-10-7
Sharpe32 Controller
PH10MQ & ACR1 Toolchanger
TP20 & TP2 Probes
Pcdmis CAD++ 3.7mr3, 4.3mr1, 2009mr1, 2010mr1
Datapage RT 3.33
Reason
We have 5 tools due to the nature of the parts that we are measuring.The parts are quite complexed and some of the operators run the programmes from Work Instruction(basic use).We have also tried to delete a tool which is same 0,1,0 50mm but diferent name,but when i come back into software the tool is back? I understand why you are asking the question about having 5 tools,i will look at trying to commonise these later,but i still won't be able to delete a tool,am i doing something wrong when i click onto DELETE TOOL.It's only a mistake if somebody else finds it!
by JoBLOCKOk I have a ?. If I add another tool dia in my probe utility, so I have 2 spheres. If I calibrate one probe with one sphere, then another probe with a...
10-30-2009, 08:24 AM -
by JamieMacDGood mourning everyone,
Yes I spelled it correctly..If you're running the demon you are in some form of mourning.
I...-
10-01-2013, 07:29 AM -
Hello all,
I have what will probably be an easy issue to fix but is taking me forever to figure out. I recently reset the software to restore...-
11-21-2017, 03:53 PM -
by BigMattHi All,
First of all, I'm new to PCDMIS. I've got experience in other packages, but that's not too fresh.
I'm working in an older...-
02-20-2014, 08:25 AM -
by aahmadI reload PC DMDIS 3.7 due to Serialization error.
when I am calibrating Probe is working fine but if I am adding angle and want to calibrate it...-
09-20-2011, 01:14 PM -
