I have an existing program for an insert that we need to check on Monday. I have been told that we are moving a molding wall by .015 and that there will be no updated model reflecting this change. I know that I can use the thickness option in the linear open scan to show this area in spec. I have used this function with a sp600 (findnoms-relearn), but the program is written for a tp20, and really involved. If I have the settings set to findnoms and normal, I have had issues with the program trying to relearn its way around the part...is this normal???? The molding walls are very close together and I know that if it tries to relearn its way around I will crash. I dont want to spend all the time reprogramming the whole insert for a SP600. Any Ideas???
thickness / scanning
You can 'shift' the tolerance to determine if it is GOOD or BAD, if you are using a form/location tolerance of +/-0.030" and you are added +0.015" of stock thickness, change the tolerance to -0.015 / +0.045.sigpic
JIMI!
Jimi,
Good to hear from you........Thanks again for giving me the 1 hr run down on datapage a few weeks ago, cant thank you enough..... The customer was happy.
As for just switching the program over to the SP600...cant do it..the program was wriiten for a TP20..Cores, and Ejector pin holes werent modeled into the ejector insert. We generated the scans then manually took out the areas to skip over. One thing that I have found out using the sp600 is that it doesnt like to skip over areas and start scanning again(defined), I start loosing more and more data, and eventually it gets lost...thinks that it is on the opposite side of the part...relearn always seems to work better, but not without the holes in the model I have to reprogram everything!!!!
by DeWain HodgeI have a part that the operation is leaving .150"-.250" stock on the part. I need to take points for the 'T' value. We don't like tolerances...
03-21-2018, 02:45 PM -
hello I am new to the forum. how could I add material thickness compensation for example I have a part that gets nickel plated and we measure it before...
06-14-2018, 03:50 PM -
by John Riggins
Is this not double-dimensioned?
Or is it a special control?-
09-18-2007, 08:26 PM -
by gsepanI'm currently using 3.7 MR2 and trying to figure out what's happening when I use "Actual" thickness when measuring surface points. When I program...
05-02-2006, 07:10 AM -
by kmcmmWhat is the best way to offset for material thickness?
TIA-
06-13-2006, 03:08 PM -
