i have a drawing that calls out the concentricity between 2 circles, i am using pcdmis 2013 (cause i haven't updated yet), but cannot figure out how to use this function? i am new to programming and dealing with plastic parts we don't get tolerances like this very often (GD&T), but have some new customers that are going to start using it. can anyone help? 10094735 - B - Pump Housing, Re-designed, AutoDose.PDF (101.3 KB) do i use the inner circle as the datum or the plane as called out in the drawing?
concentricity of 2 circles
Measure 5.2 cylinder and level and origin on it.
Take lots of vector hits on 2.25 diameter at .42 from -A-
Report difference between largest and smallest radial distance.
Concentricity reports the same as location. Don't use it. You need TIR
by dennisgilpinThe question I have is what is the difference between measuring the concentricity between 2 circles (measured as circles) of the same diameter or between...
05-08-2012, 07:43 PM -
by D-TrainWhat would be the best method for constructing a cylinder? I am making a program for a gage rod, and I am asked to measure the diameter at the ends of...
10-06-2015, 08:41 PM -
by keegoI have a tube with a bore at each end. Outside of the tube is primary datum. Would you then measure the bore features as cylinders, (3d), or circles,...
06-15-2010, 04:08 PM -
by David WedelWhy are my circles scewed to may working plane?
01-11-2012, 12:03 PM -
by Guest1) What would be the most accurate calculation method for defining circles/cylinders for the purpose of determining the concentricity of 2 circles/cylinders???...
03-27-2006, 11:58 AM -
