Hello Folks,
I quite often use edge points (plastic parts). If the edges of my parts are roughly 90 degrees, the typical "1 click" method works fine. That is one click on either the surface or the edge.
However, if there is a radius, one should use the "2 click" method. One click on the surface and one on the rad to obtain a proper vector.
Apparently, this can be changed in the settings editor.
Can anyone tell me how to be able to change this from "1 click" to the "2 click" type of measurement? I need to know how to do this back and forth.
Please explain in a simple step by step method.
I was told to go into the settings editor, and then proceed to AutoFeatures\EdgePoint. From here I do not know what to do.
Please advise ASAP.
Blessings,
ZydecoPete
Please advise ASAP.
Blessings,
ZydecoPete
