Hi all,
Loaded 3.7mr3 a few days ago. Ran several existing programs (from 3.5mr2) flawlessly.
Today started the first fresh program in 3.7mr3. Alignment (w/cad) went fine, solved ok and all was as it should be. Went to pick my first vector point and the program froze up. The EXECUTION MODE OPTIONS screen came up but was all gray. The graphic screen & edit screen went white and nothing will move/drag and no buttons will activate.
I must ctrl/alt/delete and PCDmis says "not responding" so I end task and start over. I open the program, run through the alignment, again just fine, and same thing happens whenever I try and create a point.
Any ideas????
Any ideas????
