Is it possible to scan ( with a sp-25 ) a sphere. I can not find anything that I can choose that will let me scan one. I want to check all my probes in one program with a quick qual check program. I can do normal spheres with the auto/sphere but they won't scan the sphere. Any suggestions.
Sphere Scanning(?)
Been there, done that. . . .
I've done this with the Freeform scan function. You need only to supply the path data in the form of a text file. I've done spirals most of the time, but the path is only limited by your imagination. You can create the path files using a BASIC script, or even from an Excel spreadhseet.
Originally posted by Don Ruggieri View PostI've done this with the Freeform scan function. You need only to supply the path data in the form of a text file. I've done spirals most of the time, but the path is only limited by your imagination. You can create the path files using a BASIC script, or even from an Excel spreadhseet.sigpic
PCDMIS 4.1, 3.5mr2,
Spreadsheet Export Example
Here is one example. This is a spreadsheet that can be used to generate scan points and vectors for a sphere of any size.
Change the A2 cell to show your sphere size, then when you exit that field it will fill in the remaining cells with hit/vector data.
Export this sheet to a CSV file (SaveAs). Depending on how you do this, you may need to edit the file to remove excess fields and characters. In the end, it should look like this -
-8.118533,-4.981471,0.000000,-0.852339,-0.522989,0.000000
-8.063418,-5.070199,0.000000,-0.846553,-0.532304,0.000000
-8.007330,-5.158323,0.000000,-0.840665,-0.541556,0.000000
-7.950279,-5.245826,0.000000,-0.834675,-0.550743,0.000000
-7.892275,-5.332694,0.000000,-0.828585,-0.559863,0.000000
-7.833322,-5.418920,0.000000,-0.822396,-0.568915,0.000000
for as many points as you want to include. This file format DOES NOT USE the XYZIJK file header that is used in other areas of PC-DMIS. All records are identical format.
Now, in your part program, Insert - Scan - FreeForm, go to the Path Definition tab in the dialog, and then hit the ReadFile button. Use the browser to find the data file you just created, Once selected, you should see the data points in the scan dialog path window. Hit Create, and it stores it into the part program.
I have scanned a sphere. It is a bit messy though. I created two circle scans at 90° from eachother and then constructed a sphere from the data collected.
If there is a better way I would also love to know!Please Join The Effort.
https://www.pcdmisforum.com/forum/pc...o-metric/page2 (Comment #17)
ping Don Ruggieri regarding the free form scanning generating spreadsheetPC-DMIS CAD++ 2o22.2 SP2
Another way to create the file, with a VBA script... To be used in an excel file, no need to write anything else in it...
Code:Sub Macro1() ' 'This script creates a text file with x,y,z,i,j,k values 'for an external sphere (1 hit/° around the axis) The sphere is centered on the origin, vector along zaxis. 'The text file can be used into a freeform scan. 'Hope it can be used by someone here :) Dim nbr, sph_rad, xx, yy, zz, ii, jj, kk Dim alpha, beta, pi, pas_alpha, pas_beta nbr = InputBox("enter number of rounds") sph_rad = InputBox("enter the sphere radius") pi = 4 * Atn(1) alpha = 0 beta = 0 pas_alpha = pi / 180 pas_beta = pi / (4 * 180 * nbr) Open "points_scan_sph.txt" For Output As #1 For i = 1 To ((nbr * 360) + 1) xx = sph_rad * Cos(alpha) * Cos(beta) yy = sph_rad * Sin(alpha) * Cos(beta) zz = sph_rad * Sin(beta) ii = Cos(alpha) * Cos(beta) jj = Sin(alpha) * Cos(beta) kk = Sin(beta) Write #1, xx, yy, zz, ii, jj, kk alpha = alpha + pas_alpha beta = beta + pas_beta Next i Close #1 ' End Sub
- Likes 1
by JR VILLAwhich is the best way to scan a sphere? need some help, dont know if patch or linear are the corect options to use.
04-19-2011, 07:33 PM -
Why will DMIS not let me scan an auto sphere? It is only letting me use default. First time attempting this so I'm not sure if it's supposed to be this...
03-19-2021, 11:17 AM -
by louisdHas anyone noticed that our tools available to us entirely omit our ability to replicate the scanning strategy done when calibrating a probe tip?
02-28-2020, 12:52 PM -
by JEFMANI would like to construct a sphere from 18 scans. I insert the scan in a loop from 1 to 18, and i construct the sphere with syntax "SCAN1[1..18]"....
12-08-2008, 12:02 PM -
by Jim PoehlerHi all,
Problem with my linear open scans. Most times when I run the actual part on the CMM the probe does not stop at 2 but just keeps going...-
05-20-2016, 08:00 AM -
