Perpendicularity - Max and Min.
  • Perpendicularity - Max and Min.
    I measured perpendicularity of two surfaces, one a top surface and the other side surface,
    this is the results,
    DIM BOTT.SLOT1 PERP.= PERPENDICULARITY OF PLANE PLN(BOTT.SL.),RFS TO PLANE PLN(TOP-ID BURR),RFS UNITS=IN
    AX MEAS NOMINAL +TOL -TOL MAX MIN DEV OUTTOL
    M 0.00160 0.00000 0.00700 0.00000 0.00060 0.00100 0.00160 0.00000 --#------
    DIM SIDE SLOT1 PERP.= PERPENDICULARITY OF PLANE PLN(SIDE SL.),RFS TO PLANE PLN(TOP-ID BURR),RFS UNITS=IN
    M 0.01387 0.00000 0.00700 0.00000 0.00727 0.00660 0.01387 0.00687 -------->
    I would like to know what is MAX and MIN.?
    and how is measured and calculated.
    thanks so much.
    musid
    Look at this thread, there are some explanations....
    http://www.pcdmisforum.com/showthrea...ty-circularity
      it helps, thank you.
