I have a MIH probe head and have calibrated all the probes (1 - 5) configured as a star probe with the head at A0B0. I then turned the head to A90B0 and calibrated all the probes in the orientation. When I check all the probes to a plane in the Z axis, the A0B0 check within .00013", but with it at A90B0 they all check .043 - .044". What is going on? I need help! thanks
Calibration for star probes
Go here to start...
http://pcdmisforum.com/attachment.ph...5&d=1158259178
then try this one...
http://www.box.net/public/6db96oashpsigpic
This might help too.
http://pcdmisforum.com/showthread.php?t=2816
Also, how long is the probe? It may weigh too much. Does it cause false triggers?When in doubt, post code. A second set of eyes might see something you missed.
The #1 probe is 3mm dia x 20mm long. All others are 3mm dia x 36mm long. I am using a medium force TP20 trigger probe. I have had a few false triggers, but for the most part it works fine. I do plan on buying an extended force trigger probe as soon as our company lets us buy equipment again. I will try and align the probes again and then recalibrate. I did have it aligned quite well, but will do it again.
It is the TP20 probe. The "pull" trigger is terrible and will cause your tip cals on star probes to suck pretty bad.
Well we usually advise at this point that you should begin drinking heavily and seriously consider a career change! But. . . if that course of action does not appeal to you. . . You really only have a few choices. 1) Use small and lighter tips. 2) Beg, borrow, steal, or purchase a tp2. 3) Program or reprogram to inspect the part using a single tip and many wrist angles. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by jennyHello, I am building a star probe, here is my build, once calibrating this, I then check and my data -1.4mm off. Is this because I have the wrong exten...
07-10-2012, 04:21 PM -
by BoomerI think that I might be sol here....... Because my head is rotated at a90 b0 my calibration runs fine, except for some bad deviations....Thinking about...
06-08-2007, 04:45 PM -
by Scott BrownHello Everyone
We are currently planning to use a star probe to access holes on the bottom side of a part. Our plan is to measure all top...-
12-12-2014, 09:14 AM -
by SirenHi everyone,
I have a Leitz with 4 star probes, they work very well and I did not have problems about it. The problem I have is when I...-
06-22-2011, 11:20 AM -
I am using a global image with a sp80 probe head. It does not articulate. I need a star probe with the #2 probe (-1,0,0) rotated 15 degrees about Z so...
12-08-2006, 05:53 PM -
