I am attempting to find hole "center" for an inside round slot auto feature on .090" thick sheet metal part. I use it all the time for circles and don't have any issues. It finds the hole correctly as it goes just into the slot opening and stops. The flats of the slot are on the top and bottom. When probe goes to take sample hits to determine center it first takes a point on the bottom edge of slot. It then goes straight up presumably to take a hit on the top edge but it is trying to go further than the width of the slot and crashes every time into the edge. I have verified the nominal values for the slot dimensions are correct. I have reduced the prehit also just to rule that out. I have also tried measuring another slot but same result. I believe this is actually the first time I have attempted to use find hole center on a round slot. Any suggestions? Thanks.
Find hole command issue (Auto Round Slot)...
I am in a discussion with the home office on the methodology for measuring slots. I have found that using the square slot function with find hole turned...
04-02-2008, 06:13 PM -
by Jeff HuntWhat I have is a cross between a round & a square slot. The ends of it have a radius, but that radius does not equal the diameter of the slot. Heres...
04-06-2006, 07:42 AM -
by Adam OlsonI have a slot or pocket whatever you want to call it which is datum -d-. My problem is that the slot is tapered (will attach a pic and print) and it does...
09-04-2008, 10:36 AM -
I have a square slot 3mm x 3mm, It is dimensioned to front edge and back edge of the slot. I am having a huge amount of variation in the slot location...
05-17-2006, 09:56 AM -
by ErikirI wouldn't be surprised if I'm just blind and am not seeing what is right in front of me but...
How do I dimension centre to centre of the radiuses...-
09-23-2013, 12:54 PM -
