How do you add a new probe to the probe library?
Probe library
Bob, I didnt get the answer I was after in the above (linked) thread. Is there any possibility in getting a breakdown of exactly what each line of code means (see below). Its easier to decipher for standard ball probes (still not idiot proof) but I got kinda lost with my home made disc probe.
TIA
F
comment this is the top cylinder with the threads
color 142 142 142
cylinder 0 0 0 0 0 -3 3
comment this is the cone that goes from top cylinder to shank cylinder
cone 0 0 -3 3 0 0 -7 0.65
comment this is the shank cylinder
cylinder 0 0 -7 0 0 -10 0.65
comment changes color for sphere
color 255 0 0
comment this is the probes ruby tip
sphere 0 0 -10 1
comment the hot spot is at the center of the tip with a diameter
hotspot 0 0 -10 0 0 1 1 1 ball
endtipRecently jumped from 3.5 Mr 2 CAD
to 2012 CAD++
by jkb_mcgFirst off, locate 'probe.dat' in your pc-dmis folder. Open it up. Now, highlight the first probe build. Should look something like this:
Channel: Tips & Tricks
11-11-2009, 01:02 PM -
by Alisson_CPHello people, this is my first topic. I use the forum already some time and always my doubts were resolved just by reading the topics , but i have a doubt...
07-21-2016, 02:42 PM -
by Robert.NyproHi all,
I have a problem with add special probe to PC-Dmis 2009 Mr1.
We order probe 0.3x15.25 A-5004-0664 NP/SY - Parallel hemispherical...-
05-06-2011, 10:17 AM -
by David WedelQuestion? If was to build a new tip that was ITEM:TIP1BY15.5MM M2 what would be changed in this 1by20 that is the same besides length.
03-01-2010, 06:57 AM -
by JtkuytFrom searching around the forum, I've gathered how to find and open my probe.dat file, and that I need to copy a similar set of probe data to create usrprobe.dat....
03-04-2015, 02:27 PM -
