is it possible to Pre program a part offline from a cad model and then match that program up to a fixture cad model at a later date?
working with Cad Models
Originally posted by Vikingroovin View Postis it possible to Pre program a part offline from a cad model and then match that program up to a fixture cad model at a later date?
as explained by vinni(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Program the part from an assembly of the part and the fixture. I do this 100% of the time. I always create the assembly in solidworks but there are other posts available that explain of to so it inside DMIS. Another way to look at this. When you import your iges or step into DMIS it will always start with 0.000 origin and orientation. I always place reference geometry on my cad before I create and iges so when I import it , the model is the same as it will sit on CMM. I just start programming without having to transform the cad. If I need to replace the model with a new model or updated cad + fixture, I make sure the reference geometry is the same, import the model/ assembly and only change the features that I need to. The manual align will not have to be changed with this method. ( DUH !) Your fixture cad isn't done yet is it ?
Your fixture CAD should be in the same coordinate system as your part CAD. What exactly would you be needing the fixture CAD for? The only time I ever use it is when there are SPC ports that are not designated by the drawing."This is my word... and as such is beyond contestation."
by parrottkI would like to import cad models with fixturing into my older programs.
can someone tell me the best way to get the model aligned with the program?...-
02-27-2007, 10:15 AM -
by AggieGradCan someone tell me how to do this? I have a program that has a total of 4 different CAD models. 3 for custom built fixtures, and 1 part model. We...
12-11-2020, 09:04 PM -
by sfieldIs it possible to import a model of a fixture and also a model of a part into the same program and tie them together in the way that the part would sit...
01-29-2016, 08:29 AM -
by LepageHello everyone,
does any one know how to go about coupling a CAD model of a clamp device together with a part CAD model in PCDMIS to where one...-
04-11-2007, 02:25 PM -
by afotionGood morning gentlemen,
A few questions for you today. If I want to add fixturing to a CAD model what is the easiest way? Everytime I do so I can...-
03-12-2013, 10:17 AM -
