Paste with pattern???
  • Paste with pattern???
    Whenever I use any type of math to find a surface with paste with pattern I need to manually edit... Anyone else got any ideas.
    6 inch tall 1mm thick cylinder out of round by 2.5 mm
    Need planes on the top edges and 2 more steps down for parallelism
    I take P1 as a point on the outside in the X... p2 = p1.x - .5mm moving in the Z
    When I create a 7x 45 deg polar pattern all the subsequent even numbered points refer back to p1.x and I need to manually edit them...
    This also happens with rectangular arrays...
    Any Ideas?
  • #2
    I believe there is a way to take a sample hit for vector points that will allow you to take a sample hit perpendicular to the vector that your actual hit will be, which it appears is what you are trying to accomplish.
    It may be in vs 3.7, because I can't find it in 3.5 that I'm running currently. I used to use 3.7 at another shop.
    PC-DMIS 2016.0 SP8
    Jeff
    Comment
    • #3
      Been there tried that but thanks part has an edge radius Z points sllip off
      The real issue is any variable whether in a feature or assigned when paste with pattern is used can not refer to the appropriate element from which it was taken only the original one.
      Comment
      • #4
        What version are you using? I just tried it in 3.5 MR2 and it worked fine. I took a hit with a 1,0,0 vector in the diameter(P1). Then took another point on the surface changing the target coordinates to P1.x+.2,0,0. Then I copied the two points and pasted them with a 45 angle 7 times and the 2nd point stated relative to the point right before it.
        PC-DMIS 2016.0 SP8
        Jeff
        Comment
        • #5
          3.2063 must be the problem... thanks for everything... will try in 3.7
          Comment
          • #6
            I think I remeber that being an issue with 3.2063. It seems with every version that comes out the paste with pattern changes a little when it comes to things like alignments and variables. You gotta love those enhancements/unenhancements/re-enhancements.
            PC-DMIS 2016.0 SP8
            Jeff
            Comment
            • Francisco21
              Copy Auto Points
              by Francisco21
              Hello Again.
              I have a cylinder part and i created 5 points on one side. How can i copy the same points and rotate them 45degress exact.?
              06-07-2021, 02:49 PM
            • Rick Mercer
              Paste with pattern
              by Rick Mercer
              I am looking for a way to create a circle or cylinder using points with the paste with pattern function. I use a lot of dedicated fixtureing and auto...
              10-13-2020, 11:08 AM
            • Wingman
              Radial Profile
              by Wingman
              I am running PC DMIS 3.7 MR 2.
              I have need to report Radial Profiles in a big way (most every part I do needs this). Unfortunately, I have not...
              09-01-2006, 10:26 AM
            • BANDY
              Grid of points
              by BANDY
              Is there a way to create a grid of points on a selected surface. Something like 10 points in X direction and 30 points in Y direction and 1" apart....
              01-10-2008, 01:01 PM
            • TKOFaith
              Paste with Pattern
              by TKOFaith
              Hey all,
              Running 2013. Recently upgraded from v3.2063. I'm attempting to use Paste with Pattern at 45° 7 times on a round pot. PCDMIS...
              10-09-2013, 03:53 PM
