Angle of a taper
  • Angle of a taper
    Checking a female taper angle with a tolerance of +/- 01'15" (about .02 degree). Company doesn't want to spend the $ on an airgage. Does the CMM really have the accuracy to check this?
    I suggest you try it with one part over and over to see how well it repeats first
    TK
    sigpicHave a homebrew
      Problem is the difference between repeatability and accuracy. I could repeatedly report an angle of 5 degrees +/- .02 as in spec, but its actually 5.03 degrees.
      I know most CMMs are accurate to .0002" or .0003", but I don't know how that translates into angularity.
        Then check its repeatability on the CMM and measure it with a manual method : mold and comparator. Compare results.
          sine plate the part with tenth blocks to be sure you are RIGHT on the actual angle.
          Measure the part manually and align.
          Measure the part DCC and align.
          Measure the part DCC and align. Look at the amount of error between the actual and theoreticals.
          Measure the part DCC and align. Look at the amount of error between actual and theoreticals. Still seeing improvement?
          Measure the part DCC. Look at the amount of error. Close to no delta? Is it the same as the sine plate? Yes to both, report it. Still have delta, align and do it again. No delta but doesn't match, don't use the CMM.
            I'm going to call this one as not possible on the CMM.
            The gage length of the taper is .200", which (if I remember my SOHCAHTOA correctly) means a deviation of .0002" from one end to the other would be a change of .057 degrees which is outside the tolerance of +/- .02 degrees.
            There's no way to check that on a comparator either, at least not with a x20 lens.
            • Jacek
              Accuracy of the angle
              by Jacek
              I was asked by customer what is the accuracy of an angle of our CMM. Volumetric MPE stated for our machine is 1.7+(4L/1000).
              Is there any formula...
              10-11-2014, 09:24 AM
            • mdobb829
              Reported Angle
              by mdobb829
              Can anyone tell me how I can force a reported ANGLE to the angle call out on the print? I have a 15° angle call out on the print. When I ask for the...
              08-01-2008, 04:01 PM
            • DeWain Hodge
              Reported angle
              by DeWain Hodge
              How can I get PCD to report an 327° angle instead of -33°?
              10-01-2010, 08:05 AM
            • dhoughton
              Angularity
              by dhoughton
              Can someone please help me understand how PC-DMIS calculates angularity. I'm checking the angularity between two lines that are called out at 45 degrees...
              02-23-2018, 09:29 AM
            • Jim Poehler
              Position of an angle?
              by Jim Poehler
              Good morning,
              Something new here, a position call out for an angle to be .001 to datums A and B. Anyone here experience this before and how would...
              10-02-2014, 08:50 AM
