3-2-1 aligment
  • 3-2-1 aligment
    Hello,
    Im new here and new on use this softwere...
    I use PC Dmis 4.3.
    I try to alignment my piece with 3-2-1 plane-line-point
    I make Plane1 Z axis then Plane2 y axis, i intersect the plane and i get a line after i make a point on X axis.
    When i want to alignment with 3-2-1 the program say to use a plane first so i use Plane1 and put it on Z axis after program say to use a line but he dont find my construction to use it....?is this posible?
    I do this aligment manual without 3D model.
    If you measure two points on Y plane along X axis, PC-DMIS should see the line.
    I don't use 3-2-1 alignment, but I think it works only with measured features (not sure of it...)
      Create an alignment this way.
      INSERT/ALIGNMENT/NEW
      Select features as needed for level, rotate, origins
        ok thx guys
          Originally posted by medanovidiudany View Post
          Hello,
          I use PC Dmis 4.3.
          I never liked the (constructed) line intersection of 2 planes for a rotational element
          Suggest on alignment that you either make a line in place of plane 2 or you can use the plane2 in "Y-" rotated about Z ; I am guessing that you are facing part in a typical XYZ coordinate
          Either way direction of line is huge in alignment and vectors if using a plane for rotation
            What he said. I would not use a Line constr from two planes for rotation, period!
            B&S One
            PC-DMIS CAD v2014
            Romer Infinity
