New Probe Build Question
  • New Probe Build Question
    Good day to all. I have an open question for anyone who can answer how I build a probe file using a custom built probe that is not on the drop down list in the Probe Wizard. My situation is that I am having a stylus made that has a longer stem than the standard available. Standard length is .5mm x 20mm. My stylus will be .5mm x 30mm. All the rest of the procedure I am quite able to complete, just not adding that length to the build. I am operating CAD++ 2013 MR1. Thanks in advance.
    Easiest way... FAKE IT.
    Use a 10mm ext. and the .5x20 probe.
      Sorry Matthew, that won't do it. I don't need the extension, I need the stem length so that the probe will not shank out on the part. It's tiny and deep and I need the stem length along with the small ball diameter. Nice try though, wish it were that simple.
        He's saying to "build" the probe file that way in pcdmis.
        the machine doesnt know, or care, if your actual probe is .5mm x 30mm and you " build" the probe file as .5mmx20mm + 10mm extension
          Duh, that makes more sense. Thanks BIGWIG 7 for that clarification. I do believe it will.
            Good luck getting that stylus to calibrate correctly!
            Hope you have a light force module.
              I know but I have few options to meet my needs for this.
                edit: oh because its such a small tip . gotcha.
                  Cal and measure with a slow touchspeed with this build
                  TK
                  sigpicHave a homebrew
                    TK
                    Thanks for the tip. Will do that.
                      Also use DCC+DCC for qualification, and possibly bring start angle up to 5° in qual settings
                        You can open your Probe.dat file in the PC-DMIS root and paste the below in the M2 stylus area lets say right below the "ITEM:TIP0.5BY20MM M2"
                        PC-DMIS will not see it until a software restart
                        ITEM:TIP0.5BY30MM M2
                        comment A-5003-1345
                        begintip
                        ribcount 10
                        color 152 152 142
                        cylinder 0 0 0 0 0 -3 3
                        cone 0 0 -3 3 0 0 -13 1
                        color 120 120 120
                        cylinder 0 0 -13 0 0 -30 0.3
                        color 255 0 0
                        sphere 0 0 -30 0.5
                        hotspot 0 0 -30 0 0 1 0.5 0.5 ball
                        endtip
                          comment A-5003-1345
                          begintip
                          ribcount 10
                          color 152 152 142
                          color 120 120 120
                          color 255 0 0
                          sphere 0 0 -30 0.5
                          endtip
                          What for?
                            Just so the build is actual and he doesn't have to say there is a 10mm extension there that isn't. Some people are anal about that thing.
                              Oh i see it now. Under cylinder "30"
