Can not find CAD nominals within find nominals tolerence
  • Can not find CAD nominals within find nominals tolerence
    I was making a program and almost finished, just need to check one more feature. I take a manual hit on the part and pop up says "Can not find CAD nominals within find nominals tolerance". Does any one know what this is and know how to make it go away?
    Thanks,
    Cluster Fudge Sir!!!!
    What mode are you in?
      DCC, I am not even using a cad model.
        My first thought is you have a scan command in your program.
          I used the find function and entered scn and nothing came up. Is there a way to tell?
            Save the program, exit the program, open it back up and try again. Does the message still pop up?
              I did that, even tried shutting down pcdmis. no matter where I am in the program it still pops up with the not find cad nominal thing. I ran a different program I made recently and I can add hits fine to that one, just cant take manual hits at all in this new program all of a sudden. Is there not a find nominal check box somewhere?
                Check your F5 settings, first tab (I think) see if "FIND NOMS" is marked in the list.
                  That worked guys, thanks again for the support.
                    Some of the IGES files wont pick the Nominals , try to import the CAD as a step file
                      Select 'EDIT-PREFERENCES-SETUP'
                      Select 'FIND NOMINALS'
                      If you still experienced the same error then increse the Find Nominals Tolerance.
                      Hope this solve your prolem.
                      "Learning is like rowing. Once you stop, you drift back" - B. Britten
