I have a part has an half octagonal shaped cutout on an outside surface. So my part has 4 surfaces of the octagon and the rest of the octagon is open. I need to calculate the Maximum Inscribed circle for this octagon-half. I have measured each of the 4 sides with the vision system on my CMM. I then created a constructed circle. I typed in each feature in like this: "feature_name.hits[1..feature_name.numhits]" and selected the Maximum Inscribed circle option. This then creates a circle that only touches the two outermost points that is far too large to fit inside the octagon. How should I go about measuring this feature. As a note I also get an error message saying that I have measured less that 180 degrees of the circle. This is potentially true depending on how large the circle is and where it touches the octagon. Is there a way to force PC-DMIS to touch 3 parts on the sides of the octagon?
I appreciate any insight! Let me know if my description isn't clear enough.
