Digitize
  • Digitize
    Dig'd a flow drill for the tool room, and exported it as DXF, and IGS. they want to open it and make surfaces.
    Is there a simple way of doing this (have limited autocad exp).
    Output it as points, from a specific alignment...
    3.2063
    Thanks,
    Kevin
    RFS Means Really Fussy Stuff
    Yes, do you have a pic? THATS ALL they need. Have them connect the dots. YOu could do a scan.
      Yeah, I scanned it and added the "as points" feature. I was inquireing if anyone knew the exact commands in Autocad to do this (is it real simple, or a long drawn out process?)
      Thanks,
      Kev
        Splines are better for surfacing, any programmer worth his salt would take your igs out, and surface it.
          surfacing for your CAD guy will be very hard if your scanning with a touch trigger probe.
            Hello,
            My experience with AutoCad R14 and 2000 is relevent with this question. I really don't care for splines. I prefer the single points and sweep my surfaces accordingly. I use edge points on the cmm for the trim to create my lines, rads etc from these. As for the amount of time it takes to create the surfaces,,,,,no cad guy is going to rush the job. It could take a while, no matter how small or easy the job. If the Engineering dept has inventor desktop, then creating solids or surfaces from a scan is a little easier.
            Just my .02
            A.Gore
            sigpicA.Gore
              When exporting the IGES file there are several options as to how it will be exported. Try these out to see what suits your CAD guy, and what you are trying to accomplish.
                yeah, i've done this a few times - but not recent (2yrs at least). I used to do it quitre freQ, and as I gave the Eng. Dept the "pts" it was all they needed. Somehow, we lost inventor, and are in the process of getting a new license for Pro-E , so.....
                Kev
                • NMC_CMM
                  Why don't my scans and surface points match?
                  by NMC_CMM
                  Hey all,
                  I've got a tapered oblong pocket that I'm trying to inspect for the milling dept. Usually I just take surface points off the...
                  10-08-2010, 04:23 PM
                • keith
                  CAD++ Question
                  by keith
                  pc-dmis cad++ 3.7 mr1
                  We're cutting several parts from 3D data on several different machine tools to determine which machine cuts closest...
                  08-29-2006, 04:16 PM
                • Johndk
                  How UV scan works?
                  by Johndk
                  Hi,
                  I searched everywhere for an answer but I did not find it.
                  Does someone know how are the points of the UV scan defined? Considering...
                  12-26-2011, 09:09 PM
                • WScmm
                  scanning
                  by WScmm
                  I have to do some reverse engineering. I have a SP600 head. When I usually do my scans I usually generate points after the scan. If I don't make a point...
                  05-08-2007, 04:30 PM
                • rmassarini
                  Points per scan rule
                  by rmassarini
                  I would like to know if there is a "Rule of thumb" or standard on how many scanned points there should be per liner length or tolerance. Attached...
                  11-12-2016, 07:32 AM
