True Position Explanation
  • True Position Explanation
    Does anyone know where I can find a definition as to how PC Dmis Calculates true position?
    An engineer is asking for it...of course.
    2B1ASK1
    For single axis, 2 axis or 3 axis Position?
    sigpic...engineering
      TP = 2x sq root of the sum of 1st axis dev squared and 2nd axis dev squared. Nothing new here!
      TK
      sigpicHave a homebrew
        Is he asking how True position is calculated in general (i.e. He doesn't understand it) or how PC-Dmis specifically calculates it?
          That will depend on HOW you report the TP.
          1) Straight up TP, hypotenuse of the triangle times 2 (hypotenuse = radius, TP = diameter, so doubled). If all 3 axis are reported, then it is the formula for the radius of a sphere times 2
          2) PERP-TO-CL turned on is a little more 'advanced' as in Pcdmis basically 'levels' to the nominal centerline axis and reports the hypotenuse and doubles it.
          3) Xact measure with datums(M), no way to tell you since this is WAY up there on the math skill pyramid, as there is datum shift, which you pretty much can't do by hand with a pencil & paper
          4) Xact measure without datums(M), should be the same as 1 or 2
            For 3 axis is exactly the same as for 2 axis, except that under the square root are the sum of the square of 3 axis deviations instead of 2.
              Which is the formula for the radius of a sphere.......
                In common parlance, that is not true. If you look up the radius of a sphere, you will not directly find that as an equation. You have to derive it from the equation for a cartesian sphere with a known center (Xsub0, Yxub0, Zsub0) and a known radius, R.
                If someone were to Google the radius of a sphere, the equation they are most likely to find is the derivation from the volume of a sphere, which includes pi.
                FWIW, I wasn't correcting you, I was expanding on what you said for clarity, for the above reason.
                  There are many formulas for the radius of a sphere (or a circle) and they are all derived from some other formula. In this case it is a sphere with a known center and a point on its surface.
                  Therefor, the most basic equation used by PC-DMIS to calculate POSITION (and many other things like T-value) is Pythagorean theorem:
                  a^2+b^2=c^2.
                  Ken,
                  you should tell your engineer that PC-DMIS calculates POSITION the way that the ASME Y14.5 explains it. As he is an engineer, he should know the standard well.
                    sqrt(Xdev^2+Ydev^2+Zdev^2)= radius of the sphere broken down to the very basics.
                    It matters not where the center of the sphere is (Xsub0, etc.), from the 'given' center of the sphere (nominal) when you have a point on the surface of the sphere (actual), and you know the difference (deviation) from that point to the center (theo), you can calculate the radius of the sphere with that formula.
                      It certainly does. How do you think you know the deviation? Xdev = Xactual - Xsub0. (Xsub0 is X subscript 0, or X naught)
                      Knowing this comes from knowing the XYZ nominal, which is the center of the deviation sphere. If you didn't know the nominal(aka center), you couldn't know the deviation. It is the same for TP or for 'T' values.
                        What you won't find by Google searching is R=sqrt(Xdev^2+Ydev^2+Zdev^2).
                        Actually
                        http://www.wikihow.com/Find-the-Radi...ere-Step-9.jpg
                          HE is asking how PC-Dmis Calculates it.
                          2B1ASK1
                            Just like ASME Y14.5 defines it.
                              Originally posted by Nano Vujkovic View Post
                              Whatcha refuting there Nano?
                              You can't prove I deleted anything! /hide
                              +1
