Can i add a cad model after or in the middle of programing???
  • Can i add a cad model after or in the middle of programing???
    I was programin using the actual part, but i find out that there in a CadModel for it,
    is there any way to add the MODEL and do PART=CAD aligment in the middle of the program?
    You can add a model at any time, if it will do any good or not without a LOT a screwing around will depend....
    CAD=PART isn't what you think it is.
      Import your model, and then adjust it if needed so the x-y-z matches up with how you started your program. Then you will need to either create NEW features ( on your cad model not actual part ) and replace the existing features in your manual align ( answer "no" to changing the align ) or adjust the theo's of your manual alignment features so they match up with the cad model.
        Origin cad model same as your part program oriented then import.
          Start a new program and import your model, do a manual alignment on model then copy and paste everything except your manual alignment from your old program maybe??
            OK, so you’re in the middle of the program and CAD X is machine Y and your customer doesn’t want the CAD coordinate to be altered in anyway, only part/machine, then what?
              Transform/align as needed
              Measure everything as required along with all the proper (local) alignments
              THEN (if necessary), create an alignment to report in the desired/required XYZ orientation.
              I have had very few complex parts that did not require local alignments (not on the drawing) but the end results still matched the drawing.
                Yeah, but you’re not allowed to Transform the CAD, then what?
                Redo the alignments after half way through makes no sense to me. Might as well finish it without CAD unless it really is a complicated part
                  Save as the program first, most likely you will screw it up!
                  B&S One
                  PC-DMIS CAD v2014
                  Romer Infinity
                    https://drive.google.com/open?id=0B9...LW8&authuser=0
                      The CAD coordinates are not being "altered" in any way. I don't believe PC-DMIS has that capability. The CMM is altering the orientation/relationship it has with the CAD.
                        What do you mean?
                        i do CAD=PART when i start my manual aligment and i am actualy measuring the part, then i do my aligment and CAD=PART so i can start my DCC aligment on the CAD.
                          Yep, because you are using CAD 'nominals' in your alignment offsets.
                          If the CAD data does NOT match what you used for alignment, clicking on CAD=PART will not magically make the CAD data match any existing alignment.
                          If you aligned off the corner of a square block and called that corner X0Y0Z0 and programmed half the part, then found out that there is CAD data for that square block, so you import it. Then do CAD=PART. Won't have any good effect if the same corner of the cad that you called X0Y0Z0 on the part is actually X-3, Y+2, Z17 in the cad data.
                            Fix nominals and vectors in manual alignment, then load CAD model in and rotate and orientate the model into the same position as your CMM part co-ordinates, using CAD transform in drop down menu:
                            Operation/Graphic Display Window/Transform
                              Yes, that is exactly what i do.
