Today, I am quite frustrated. Running 3.7mr3.
Measuring a hole in plastic, with cad. If I want to use 3 initial & 3 permanent hits, only one of the hits will be on the surface that I want to use.
I know that you are supposed to be able to "move" the hits in this version.
Method; I select auto feature, then circle. Next I select 3 initial and 3 permanent, with 5 hits in the hole.
I then select the hole on the cad, change angle to start 0, end 360.
Next, right mouse click on one of the "hits", I then select "user defined".
I then select and drag the surface sample hits where I would like them.
After this, it does not matter what I do, when I go back to the feature in the edit window and f9 the feature, the hits have reverted back to the "default".
Why?? Please help??
Regards,
zydecopete
