Report Issue
  • Report Issue
    Has anyone had their report duplicate the outputs? Example, report is normally 8 pages long, now its printing 16, even 24 pages....the extra pages are the same as the first 8.
    MS RENEE
    Make sure the Print Command says "PREVIOUS_RUNS=DELETE_INSTANCES".
      Yep, I've seen it happen before. I still don't know what was causing it. My fix at the time was just to quit the program and reopen it. I haven't seen it happen in a while now.
        pcdmis appends each executed command onto a list. This list is used to generate the report. When the program is executed (by the execute button) the list is cleared of all prior entries. If the program is executed from cursor (or looped in any manner) the list is not cleared prior to execution. Prior versions worked the same way - pcdmis appends to execute. The report would contain all items in that list.
        Not sure when it was added but there is File/Reset Execution List - which will clear any items.
          I had the same issue. Check out post 471170
          I'm having this issue with the report window compiling all the previous reports. It seems to be storing all the data and bogging down the system, where the report window has over 300 pages of reports. I know I can show just the last run report but it's still slow to start running the program for the next part. How do I clear
          • SABarber
            SABarber commented
            What have you tried.
            How are you executing.
            Is there any looping.
            So little information gleaned given.
        • gishak
          Reporting Help
          by gishak
          Can some one please tell me why iam a having an issue when measure mor then one part and i print a report i get more then one report the only way to get...
          03-06-2015, 10:36 AM
        • THOMSON_CMM
          Reporting
          by THOMSON_CMM
          I'm having this issue with the report window compiling all the previous reports. It seems to be storing all the data and bogging down the system, where...
          01-24-2019, 10:20 AM
        • j cooper
          clearing the report
          by j cooper
          When writing and testing a program how do you get the printed report to clear each time you test the program ?
          01-10-2013, 12:07 PM
        • Paul Hewitson
          Report Window Help
          by Paul Hewitson
          Hi everyone
          I have a program which I have run almost 100 times since February.
          In the last week or so, something has changed....
          07-22-2008, 09:02 AM
        • caryweaver
          Slow report update
          by caryweaver
          Is there some way to keep the report from refreshing every time I go back and remeasure or run a feature? The computer just stops for like 30 seconds...
          04-28-2018, 11:02 AM
