Unstable vector's
Unstable vector's
What am I doing wrong here? Using 3.7, MR3. No CAD model, in this case. While working with Auto features. the vector changes when I hit the create button. This causes a mis-hit of course and I have to correct the vector and remeasure. Normally it is ok the second time. Not always though. Thanks for your input.
sigpicRAH
B&S GI 10-7-10
PH10MQ-SP600M
3.7 MR3Tags: None
Open up the 'advanced' features (in the DCC Features window) and make sure that the TARGET vectors match your actual vectors. I have seen this (not yet in V3.7) before, it is VERY maddening to type in a vector in the window and have Pcdmis decide to use some other vector than the one you just typed in. I guess hits 'enhancement' that has been around since V3.5 no mr was just too much fun so they left it in.sigpic
OK, lets check this:
Are you hitting the TAB key after you have typed in the new vector for ALL 3 vector values? OR, are you hitting enter after you type inthelast vector? DO NOT hit enter until you want to measure it. When you hit enter it will (has in the past) act like you clicked on the CREATE button. If you were just finished typing in a vector, but didn't hit tab, it may (nad this is only may) be seeing the 2 vectors that have been entered, but is still 'seeing' the previous value for the third vector. When the vectors do not trig out correctly, Pcdmis will correct them so that they DO trig out correctly. So, if the third, 'unfinished' vector is drastically different than what it needs to be, this might be causing the problem. Just an idea.sigpic
Matt I think that is the issue...IMO
how else would it conjure up a another vector , unless it was from the prior feature values.
I would like to see the function of the tab and enter work together so there isn't a difference in actions between them.
Enter should take the current state of each field in the window as it stands when the button is pressed.
TAB should and does do it why not the "enter" button?......hmmmm
I found similar differences in the DONE button and the OK button......
One guy programs the DONE button in CA the OK button must be programed in NYsigpiccall me "Plum Crazy"....but you only go around once!
by TestedI'm runnung V4.1 and any of the programs that I build without CAD always come out with PNT & PLN vectors backwards. Is there A setting that I've ...
09-20-2007, 07:27 AM -
by mconklinI am having problems with the vectors having to be changed when i make a program to match from hits to the theo
10-14-2009, 03:34 PM -
by UnderspecIs this fixed in v4.2? It's very annoying
07-18-2007, 02:16 PM -
by John KuglerNot sure if this was brought up before, but I am taking single points on a 2D CAD model and my points do not have the correct vectors. They are all straight...
05-31-2007, 11:33 AM -
by AmberI am typing my theo vectors in, but they keep changing? Any ideas why this would happen?
10-29-2014, 11:15 AM -
