I'm trying to create points from auto circles using the "To Points" program I found on this forum. I created them fine from a hole & stud auto circle. I'm trying to measure wall thickness at point locations. I've been verifying these wall thicknesses with a caliper and I'm about .030" off. Anyone know what kind of points these auto circles give us? Any difference between a hole & stud circle?
Creating points from an auto circle
What version are you using?
I noticed when I upgraded to 4.1 that for some reason the points I was generating with the "ToPoints" was not probe compensating???
I never had a single problem in 3.5 or in 3.7 though...sigpic
PCDMIS 2012
Windows Office XP
The only problem I have with the topoints is after I run it I have to save then exit ALL the way out of pcdmis and go back in and turn the edit window back on. Never figured what was wrong.sigpic
I use this a lot running 3.7mr3 and the issues I have are #1-The vectors jump around. I can create the points from an auto circle that is perp to my base plave and my K vectors are never zero. #2-If I edit any of the points my vectors flip.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by sluggo9000Does anyone have a rule of thumb for the amount of points to use when measuring circles?
I never use less than five and as the hole gets bigger(3-4")...-
03-19-2012, 04:41 PM -
by Jonathan SIs it possible to report the deviation of individual points from an auto circle? Other auto features?
03-11-2006, 10:37 AM -
by MattMI was in the middle of making a program for a plate that has numerous circles on it. Midway through I must of hit something by accident because now anytime...
06-13-2013, 08:48 AM -
What i've done is created an auto circle with 10 points. I need to create a move point and a probe rotation in the middle of the 10 hits. If it can...
04-11-2006, 03:54 PM -
by mbpgiHello,
I'm still learning PC-DMIS and feel like I learn something new everyday. Anyways, I am working with a print which gives xyz coordinates for...-
09-29-2016, 05:31 PM -
