I am measuring a simple chamfer in z+ as a cone and want the angle of the cone. Every time I dimension it come up 90 deg. I know this cant be true. It is more like 30. Does 4.0 do this differently?
Whats up with this cone?
My first guess would be it is a 45 degree chamfer which would be 90 degrees inclusive. To the best of my knowledge the only way to report the angle of a single side in pc-dmis is by using a variable and deviding the angle value pc-dmis reports by 2. If you need an example of how to do this, I think there is one in the code section, if not post again and I will come up with something. I just report the inclusive angles and put a document note in my report that it is the inclusive which is twice the print callout. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
I use 3 lines for chamfers. One of the face, one on the chamfer surface and one on the ID/OD. You can depth and angle. All measured square to each other.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by dwade View PostI use 3 lines for chamfers. One of the face, one on the chamfer surface and one on the ID/OD. You can depth and angle. All measured square to each other.
by Eva HerterHI ALL,
I have a CONE and this cone is tilt 14deg..Once this cone has tilled one side becames 90 DEG and the other side becames 62deg. MY...-
12-07-2012, 01:48 PM -
by J. LuskHow would you measure the angle of the face of a cone in relation to an adjacent plane? I'm getting a close but no cigar (48 deg. -vs- 50 deg.) When I...
08-19-2008, 05:13 PM -
by Duke_26I am measuring a cone using the autocone feature on a shaft ( 3 levels, 10 hits each level ) and would like to know how I can report the angle of the...
02-01-2012, 08:10 PM -
by mdobb829When you report a cone angle is gives you the included angle. Can you make it report the angle of the taper, or as some call it, the per side angle?
07-01-2008, 11:17 PM -
by GEllsworthUsing 4.2 CAD ++ and I know I figured this out in the past, but for some reason I can not get it to give me the correct angle of the cone. The drawing...
03-19-2009, 06:44 PM -
