Have a quick question on how PC-DMIS calculates the surface profile dimension. Im am trying to do the profile of a vibra-weld rib on a part, the print calls out a few distances between lines, radii, and distances from origin. When I go to dimension any of these features they are not available to select from to form the feature control frame, only points. So I created a point from every single hit I took of the locations (like cir1.hit[1]) and then dimensioned all of the points. Without really being able to see how PC-DMIS calculates this I am unsure about using this as my recorded measurement and have just been doing it the old way of dimensioning all the features and recording the largest deviation times 2. I was curious if someone could give some insight on how this is calculated, why wont it let me pick features only points, and if using all the points is accurate. Thanks.
Profile of a surface questions
Basically -
- Construct a Set from individual points for the applicable feature
- Dimension a Profile the Set according to the drawing FCF
- Form or Form and Location
- ISO or ASME Tolerances
The Profile value is calculated differently depending on how it is set up. If you can provide a specific example, a specific answer can probably be provided.
This subject comes up pretty frequently, there should be other threads that might answer your question(s) as well.sigpic
Originally posted by Nano Vujkovic View PostWhat kind of features are you picking up, and what kind of profile are you measuring? For example, you can't measure a surface profile of a circle!!!Lately, it occurs to me
2017 R1 (Offline programming)
Originally posted by Nano Vujkovic View PostI guess in Legacy mode you can, but i never had luck using profile of a surface on circles, lines,... In Xact, linear features won't even show up for selection. So that's why!!!
It can be very helpful when trying to determine the exact nature of form problems, like out of round, taper, etc.Lately, it occurs to me
Originally posted by Nano Vujkovic View PostI guess in Legacy mode you can, but i never had luck using profile of a surface on circles, lines,... In Xact, linear features won't even show up for selection. So that's why!!!Che Guevara is a communist scumbag.
Originally posted by Nano Vujkovic View PostI guess in Legacy mode you can, but i never had luck using profile of a surface on circles, lines,... In Xact, linear features won't even show up for selection. So that's why!!!sigpic...engineering
Originally posted by Obelix View PostFor profile of the line or circle, 2D features, you have to select "Profile of the Line" first, then you will have option to pick them. If you select "Profile of the Surface" first, PcDims will not give you an option to pick 2D features.
Originally posted by Obelix View PostEven if your print is asking for Profile of the Surface, but you measured as a single line scan, you have to use Profile of the Line in PcDmis to have the option of selecting it.
simply put:
----------------- LINE
-------------- SURFACE
(i concur)
by TCeckelsAs some of you know I've been getting some "interesting" prints to work from lately and because of them several questions have popped up....
04-02-2008, 01:29 PM -
by kdizzleI am pretty new to GD&T dimensions. Can someone help me out on a surface profile callout? I am using the legacy dimensions on V4.2 because I don't...
10-05-2010, 12:52 PM -
by optonGents,
I inspected profile on a part in several sections (cylindrical part) as a Measure Set (16 hits in every section) and tolerated in rel to...-
12-14-2018, 11:54 AM -
by markyIf I measure a 2D circle and want to know its profile (not form or roundness), would I dimension it as "profile of a line" and is this how I...
05-16-2011, 08:31 AM -
by unchartedI was curious to know we have a vendor who has a CMM that is not capable of calling out profiles. Print calls for profile off of a surface. My question...
08-13-2014, 11:02 AM -
