My probe qualification test
  • My probe qualification test
    I just calibrated my probe tips, ran the probe qualification test I made and the deviation seems high to me. Is this normal and can anyone see anything wrong with the way I am doing it? [code]PART NAME : sphere probe test
    PNT1       =FEAT/POINT,CARTESIAN
                THEO/<368.35752,537.20127,-386.65476>,<0,0,1>
                ACTL/<216.12054,512.18591,-386.60666>,<0,0,1>
                MEAS/POINT,1,WORKPLANE
                HIT/BASIC,NORMAL,<368.35752,537.20127,-386.65476>,<0,0,1>,<216.12054,512.18591,-386.60666>,USE THEO=YES
                ENDMEAS/
    A1         =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                ALIGNMENT/LEVEL,ZPLUS,PNT1
                ALIGNMENT/TRANS,XAXIS,PNT1
                ALIGNMENT/TRANS,YAXIS,PNT1
                ALIGNMENT/TRANS,ZAXIS,PNT1
                ALIGNMENT/END
                MODE/DCC
                CLEARP/ZPLUS,5,ZPLUS,5,ON
                MOVE/CLEARPLANE
    SPH1       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                THEO/<0,0,-12.49>,<0,0,1>,24.9668
                ACTL/<-0.16438,0.50503,-12.48723>,<0,0,1>,24.99069
                TARG/<0,0,-12.49>,<0,0,1>
                START ANGLE 1=0,END ANG 1=360
                START ANGLE 2=0,END ANG 2=0
                ANGLE VEC=<0.1714618,0.9825222,0.0724638>
                SHOW FEATURE PARAMETERS=NO
                SHOW CONTACT PARAMETERS=YES
                  NUMHITS=25,NUMROWS=3
                  SAMPLE HITS=0
                  AVOIDANCE MOVE=NO,DISTANCE=0
                SHOW HITS=NO
                MOVE/POINT,NORMAL,<2.51638,-309.92355,28.28343>
    A2         =ALIGNMENT/START,RECALL:A1,LIST=YES
                ALIGNMENT/LEVEL,ZPLUS,SPH1
                ALIGNMENT/TRANS,XAXIS,SPH1
                ALIGNMENT/TRANS,YAXIS,SPH1
                ALIGNMENT/TRANS,ZAXIS,SPH1
                ALIGNMENT/END
                LOADPROBE/4X40XM2
                MOVE/CLEARPLANE
                MOVE/CLEARPLANE
    SPH2       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                THEO/<0,0,0>,<0,0,1>,24.9668
                ACTL/<-0.00079,-0.00031,0.00388>,<0,0,1>,24.9902
                TARG/<0,0,0>,<0,0,1>
                ANGLE VEC=<0.1716326,0.9824924,0.0724638>
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                4x40 @  a0 b0
    DIM LOC1= LOCATION OF SPHERE SPH2  UNITS=IN ,$
    GRAPH=OFF  TEXT=OFF  MULT=1000.00  OUTPUT=BOTH  HALF ANGLE=NO
    AX       MEAS    NOMINAL       +TOL       -TOL        DEV     OUTTOL
    X     -0.00003    0.00000    0.00020    0.00020   -0.00003    0.00000 ---#-----
    Y     -0.00001    0.00000    0.00020    0.00020   -0.00001    0.00000 ----#----
    Z      0.00015    0.00000    0.00020    0.00020    0.00015    0.00000 -------#-
    D      0.98387    0.98387    0.00010    0.00010    0.00000    0.00000 ----#----
    END OF DIMENSION LOC1
                MOVE/POINT,NORMAL,<-135.51581,-161.69685,17.00962>
                TIP/T1A45B180, SHANKIJK=0, -0.70711, 0.70711, ANGLE=180
                MOVE/CLEARPLANE
    SPH3       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                THEO/<0,0,0>,<0,-0.7071068,0.7071068>,24.9668
                ACTL/<0.00225,-0.00079,0.00409>,<0,-0.7071068,0.7071068>,24.99019
                TARG/<0,0,0>,<0,-0.7071068,0.7071068>
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                4x40 @  a45 b180
    DIM LOC2= LOCATION OF SPHERE SPH3  UNITS=IN ,$
    X      0.00009    0.00000    0.00020    0.00020    0.00009    0.00000 ------#--
    Y     -0.00003    0.00000    0.00020    0.00020   -0.00003    0.00000 ---#-----
    Z      0.00016    0.00000    0.00020    0.00020    0.00016    0.00000 --------#
    D      0.98387    0.98390    0.00010    0.00010   -0.00003    0.00000 ---#-----
    END OF DIMENSION LOC2
                MOVE/POINT,NORMAL,<-101.00287,-87.71786,12.03046>
                TIP/T1A90B180, SHANKIJK=0, -1, 0, ANGLE=180
                MOVE/CLEARPLANE
    SPH8       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                THEO/<0,0,0>,<-0.0000003,-1,0>,24.9668
                ACTL/<0.00191,-0.00067,0.0034>,<-0.0000003,-1,0>,24.99067
                TARG/<0,0,0>,<-0.0000003,-1,0>
                ANGLE VEC=<0.1714621,0.9825221,0.0724638>
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                4x40 @  a90 b180
    DIM LOC7= LOCATION OF SPHERE SPH8  UNITS=IN ,$
    X      0.00008    0.00000    0.00020    0.00020    0.00008    0.00000 ------#--
    Z      0.00013    0.00000    0.00020    0.00020    0.00013    0.00000 -------#-
    D      0.98388    0.98387    0.00010    0.00010    0.00001    0.00000 ----#----
    END OF DIMENSION LOC7
                MOVE/POINT,NORMAL,<-18.57470,-159.29071,258.84094>
                TIP/T1A0B0, SHANKIJK=-0.02761, 0.01507, 0.99951, ANGLE=0
                LOADPROBE/1_5X20XM2
                MOVE/CLEARPLANE
    SPH4       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                ACTL/<0.00087,-0.00068,0.00398>,<0,0,1>,24.99007
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                1.5x20 @  a0 b0
    DIM LOC3= LOCATION OF SPHERE SPH4  UNITS=IN ,$
    X      0.00003    0.00000    0.00020    0.00020    0.00003    0.00000 -----#---
    D      0.98386    0.98387    0.00010    0.00010   -0.00001    0.00000 ----#----
    END OF DIMENSION LOC3
                MOVE/POINT,NORMAL,<-119.69118,-187.07233,68.25403>
                MOVE/CLEARPLANE
    SPH5       =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                ACTL/<0.00143,-0.0017,0.00425>,<0,-0.7071068,0.7071068>,24.98947
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                1.5x20 @  a45 b180
    DIM LOC4= LOCATION OF SPHERE SPH5  UNITS=IN ,$
    X      0.00006    0.00000    0.00020    0.00020    0.00006    0.00000 -----#---
    Y     -0.00007    0.00000    0.00020    0.00020   -0.00007    0.00000 --#------
    Z      0.00017    0.00000    0.00020    0.00020    0.00017    0.00000 --------#
    D      0.98384    0.98387    0.00010    0.00010   -0.00003    0.00000 ---#-----
    END OF DIMENSION LOC4
                MOVE/POINT,NORMAL,<-7.02906,-207.13231,138.60538>
                TIP/T1A90B180, SHANKIJK=-0.00001, -1, 0.00264, ANGLE=-179.86763
                MOVE/CLEARPLANE
    SPH10      =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
                THEO/<0,0,0>,<0.0000061,-1,0>,24.9668
                ACTL/<0.00143,-0.00094,0.00411>,<0.0000061,-1,0>,24.99035
                TARG/<0,0,0>,<0.0000061,-1,0>
                ANGLE VEC=<0.1714558,0.9825232,0.0724638>
                  SAMPLE HITS=0
                SHOW HITS=NO
                COMMENT/REPT,
                1.5x20 @  a90 b180
    DIM LOC9= LOCATION OF SPHERE SPH10  UNITS=IN ,$
    Y     -0.00004    0.00000    0.00020    0.00020   -0.00004    0.00000 ---#-----
    END OF DIMENSION LOC9
    Cluster Fudge Sir!!!!
    I see most of the deviation is in the Z axis.
    Do you have any idea why?
    Lately, it occurs to me
    2017 R1 (Offline programming)
      Very good for TP2
      So so for TP20/TP200
      Could be better if you’re using analog probe
      Instead of PNT1, Origin, DCC, SPH1, I would start out with DCC, SPH1 with one sample hit, start angle 2=15, end angle 2=90, origin. Re-measure the sphere with the same tip, start angle 2=0, end angle 2=90, with no sample hit, origin.
      Just my .02
      Edit: 7 points, 2 levels is good enough in my opinion
      DungT
      Ultra Senior Member
        I have no idea why right after calibration there is so mutch deviation in the Z axis.
          Originally posted by DungT View Post
          Very good for TP2
          Just my .02
          I am actually using a SP600 scanning probe head. I wish this thing had a TP200 on it.
            .0001 to .0002 deviation seems reasonable to me.
              After your Dcc SPHERE and your alignment to that , do another sphere and create 1 more alignment to use a 0 / 0 / 0 fot the rest of our probes. This refinement of your alignment may get you a little better#'s ? Sorry missed DungT's post
                First thing to look at is......
                WHAT are your machine specs? Never, ever expect anything better than the base machine specs.
                  I agree with you on this one.
                  Those #'s actually look pretty decent. If you see more than your machine specs there is a problem.
                  Jesse Krook
                    I did end up adding the additional sphere and aligned to it and the numbers did change and for the better, thanks.
                      We have a global image machine with a sp600 on it. I was unable to find the spec for it or atleast anything layman enough for me to understand.
                        Aside from the OP question...
                        You have no rotations in your alignments.
                        Sphere or not, ya' needa rotate every time you level.
                        Use an Alignment line, Generic line, whatever...
                        But you must rotate to something, even if it's fake.
                        Pariah
                        Senior Member
                          Good spot - or in this case don't bother levelling - simply origin xyz in the sphere.
                          Applications Engineer
                          Hexagon UK
