Is there any way to query in PCDMIS to determine what the current PH10 physical probe angle is? And is there a command to move a probehead to a particular angle without having a tip assigned to it?
Probe angle
Tags: None
Well, you can get the current angle simply by opening up the PROBE UTILITIES window, it will automatically add the current angle to the list of tips, if it is a tip already in the probe file, it won't add it, that is the only way that I know of.
Oh, and it will not move to an angle unless it is in the probe file.sigpic
if your programing using autofeatures, turn on the PH9
this will let PC_Dmis figure out the optimum probe angles for you
haven't really done much with this myself, but have been happy with what it does so far
bobWhich one gets ridden today? MPH vs MPG..tough choice, both are FUN
Starrett RGDC 4028-24 :alien:
I am trying to determine the physical A and B angles of a probehead at the very beginning of a program to determine if it will hit anything, in case the last program left the probehead in a "bad" way.
I dont want to rotate the head to a known angle until I know where it is.
As a rule I ALWAYS finish my programs by using move points to place the head away from the part and rotate to A0B0.
I think what you are trying to do sounds like a good place to put a comment. Query the operator "Is the probe head in a safe position to rotate?" Doesn't it do this automatically anyway? Mine does.
Originally posted by cmmguy View PostI am trying to determine the physical A and B angles of a probehead at the very beginning of a program to determine if it will hit anything, in case the last program left the probehead in a "bad" way.
It will not matter what angle you are at or what angle you need to go to, Pcdmis will ALWAYS rotate the head to the first angle in the program, even when it is already at that angle. AS for finding out where it is and if it can rotate, nope, you are out of luck. This is where the clearance plane really comes in handy, at least in V3.7MR3. They finally fixed MARK-ALL, NO MANUAL bug (from V3.5) so that the manual angle at the beginning will not get marked or used, so the CLEARANCE PLANE move will take place WITHOUT the probe chaning angle, so you can get clear for the tip you need. This is the one time when ya just can't argue about a clearance plane being a handy, useful item.sigpic
At the end of every program, add a move point to place the probe at the top, rear and center of machine. Then rotate your wrist angle to A0 B-180 or +180. This way your head is always out of the way, it will be at the correct wrist angle to change a tip with an auto joint without having to rotate the probe.
Other things to keep in mind are: if you have very long probe extensions, you may want to keep the head low enough so that if it rotates to A105 it won't hit the bridge and make sure it is far enough away from the columns that it won't swing into them. We start out programs with the program loading the tip and rotating to its starting wrist angle before we load the part, that way we are sure that it won't rotate into the part either.
I'm sure there are other ways also, just something more to consider.sigpic
PCDMIS 4.1, 3.5mr2,
Yup, I understand all of the stuff about moving to a safe location at the end of the program. I wanted to know if the current physical probe angles could be determined programmatically. It sounds like the answer right now is No. Which kinda sucks... Thanks for the info.
So Matt, you are saying that the Z will move to the Clearance plane prior to the initial probe index? How does it know what the coordinate system is at that point in the program?Last edited by cmmguy; 11-10-2006, 03:24 PM.
cmmguy,
Take a look at this code.
Code:STARTUP =ALIGNMENT/START,RECALL:, LIST= YES ALIGNMENT/END MODE/MANUAL CHECK/ 0.1,1 TOUCHSPEED/ 1 LOADPROBE/6X10DISCX40 FORMAT/TEXT,OPTIONS,ID,HEADINGS, , ;NOM,TOL,MEAS,DEV,DEVANG,OUTTL, MODE/DCC CLEARP/ZPLUS,-3,ZPLUS,0 MOVE/CLEARPLANE MOVE/POINT,NORMAL,1,1,-3 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 MODE/MANUAL PNT1 =FEAT/POINT,RECT THEO/2.6393,19.644,-14.0778,0,0,1 ACTL/2.6393,19.644,-14.0778,0,0,1 MEAS/POINT,1 MOVE/CLEARPLANE HIT/BASIC,NORMAL,2.6393,19.644,-14.0778,0,0,1,2.6393,19.644,-14.0778,USE THEO = YES ENDMEAS/ A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES ALIGNMENT/TRANS,XAXIS,PNT1 ALIGNMENT/TRANS,YAXIS,PNT1 ALIGNMENT/TRANS,ZAXIS,PNT1 ALIGNMENT/END MODE/DCC PNT2 =FEAT/POINT,RECT THEO/0,-0.0001,-0.0002,0,0,1 ACTL/0,-0.0001,-0.0002,0,0,1 MEAS/POINT,1 HIT/BASIC,NORMAL,0,-0.0001,-0.0002,0,0,1,0,-0.0001,-0.0002,USE THEO = YES
Originally posted by cmmguy View PostYup, I understand all of the stuff about moving to a safe location at the end of the program. I wanted to know if the current physical probe angles could be determined programmatically. It sounds like the answer right now is No. Which kinda sucks... Thanks for the info.
So Matt, you are saying that the Z will move to the Clearance plane prior to the initial probe index? How does it know what the coordinate system is at that point in the program?sigpic
by BlockayHey folks,
I've built a probe and im trying to get a particular angle, A90B-90 to be exact, and for some reason PCDMIS will just not allow...-
08-12-2020, 02:18 PM -
by White06REXHello All, is their a way to give each Tip Angle/ Styli Angle a Unique name? What i am trying to accomplish is i have a customer that would like me to...
09-11-2015, 11:38 AM -
by UnderspecLooking for a solution to solve this issue....
An error occured while I had the probe head in the angle position and when I reran...-
04-26-2006, 04:55 PM -
by Tito81HI,
Just wondering why whenever I rotate the probe in the middle of the program it doesn't rotate complete angle for example: TIP/T1A0B0, SHANKIJK=.0016,...-
08-29-2019, 02:32 PM -
by j.gonzalezIm trying to check a part with a 50' angle hole with a tolerence of +/- 1/4 deg i cant use the 52.5 angle is there anyway to add a 50' angle or is there...
02-11-2009, 10:26 PM -
