Hello. If anyone has input as to why I cant print my graphics display features i would appreciatie it. For some reason it only prints the lettering and the line going to where the feature is supose to be. I have the settings on scale to fit page. thanks
Im not able to print features of graphics display window
I am using version 3.7
Good day to all.
I went to edit> preferences> edit window layout>report> all boxes are checked including show features and alignment. It still doesnt print the features, only the identification label and a line. Also I should mention on the graphics display print preview all of the features are present. It for some reason just wont print them. Thank you for any input.
Dan B. Las Cruces n.m.
another option:
go to Operation\Graphics Display Window\Screen Capture To\Clipbaord
paste into an excel or word doc.
if it looks wierd adjust per this thread:
http://www.pcdmisforum.com/showthread.php?t=1858
Try
Going to your Graphics display window - right click on any of the labels - choose hide all labels - then do scale to fit.
If you get your features on the screen then the problem may be the automatic label position is on - if that's the case then goto edit - preference - setup - scroll down and uncheck automatic label position.
JRZPC-DMIS CAD++ 3.7 from 4.2 MR1
by MFCguyHow do I force the Graphics window to print after every part run?
I am trying to loop a program and plot the form of a circle. And cannot find...-
10-12-2007, 11:04 AM -
by vpt.seHey all,
I have tried to get the actual view in the graphics window to print with the report. Using the menu options to send a screen dump...-
09-26-2008, 05:09 AM -
by norkamusHello all. This is my first post. I come from v4.3, and am new to PC-DMIS 2015. I have about 12 years under my belt on the CMM.
Question:...-
02-03-2016, 10:15 AM -
by caryweaverDoes anyone know how to use code to print the graphics window in version 3.7?
Channel: PC-DMIS Code Samples
04-10-2015, 09:33 AM -
Running 3.7 mr3 with dual monitors.
Having an issue with graphics not printing.
Edit window prints fine and the drop down...-
02-27-2007, 04:44 PM -
