Go into the PC-DMIS directory in your hard drive and open a file called probe. This list all probes for when you build a probe file. Scroll down & find the closest disk probe. That appears to be what you want. Copy & paste at bottom of page & then remame. Edit parameters to match what you have.
Hey chaps, I've added the tip to my probe.Dat file but I have screwed something up and I'm not sure what. Could some kind soul tell me what I should be putting in the .Dat file for my above probe (drg is in my 1st post)?
Using PCDMIS 2013 mr1. How does one create custom probe tips, like a special diameter disk probe that's not on the Renishaw pull down list? I did a forum...
I have a 10mmX10mm Disk Probe in my arsenal that I would like to use in one of my programs but I cannot find it in the probe list when constructing a...
I'm trying to build a probe for my Company's CMM and the stylus I want to use isn't available from the drop down list. Its dimensions are 0.7 x 21 (yes,...
