Mirroring after replacing CAD
  • Mirroring after replacing CAD
    Any of you have this problem?
    Create a program... mirror it for the opposite hand part. All is well (except for the dammmmm tip problems).
    Now, I get new CAD that may have some slight surface changes.
    Run that and update the nominals.
    Now, I mirror the updated program and the CAD and points no longer have relations.... they are in the process of a severe separation and in fact have filed divorce papers!
    Lately, it occurs to me
    2017 R1 (Offline programming)
    i would write a new program with the new CAD.
      Have you tried rehitting CAD=PART? I've had to do that before when bringing in a new CAD file.
        Yea, that is what I was hoping to avoid..... 16 hrs +
          Don't use CAD=Part
            Another option is simple run the program OFFLINE or SHOW PATH LINES. The XYZ actuals of all those points will still be PRE-MIRROR, only the nominals will mirror. Put your cursor on ONE point, hit F9 and see where it places the probe, at the point in space or on the CAD data.
              Matt, I don't follow.
              I can get the programs to run. The CAD is not in the correct place.
              I can also get the CAD to match by mirroring the CAD only, however, after the program is closed and then reopened the CAD reverts to its wayward condition. So, I will need to mirror the CAD every time we run a program like this if we want to "see" where any problems are or do any edits on the CAD.
                Well, what version are you using? You aren't a 4-head, are you?
                You are not using a CAD REFERENCE are you? If you are, that is your problem, when using a CAD REFERENCE, the original CAD is NOT affected by anything you do with it in the program.
                  must be a big part.
                    Did you mirror in "Y"
                    Not sure if this is it?
                      Not Cad REFERENCE.
                        Naw, I have mirrored these parts before with no problems.... only having problems when I replace the CAD in the -1 program and then mirror that to make a -2.
                          3.7 MR3, but importing the CAD (CATIA) with 4.1.
                          I have been doing this since 4.1 came out, and this is the only problem I have encountered with this importing method.
                            I would check the CAD file and PRG File and make sure the correct CAD file id being used and saved.
