When starting up 3.7mr3 I get a message stating "Invalid Volcomp configuration, volcomp will not be used". What is this and how do I fix this? Thanks for the help.
Volcomp message?
I can not find a file named comp.dat in the 3.7mr3 folder. I also have 3.5mr2 loaded and that comes up fine. I look in the 3.5mr2 directory for a file named comp.dat and I cannot find it? I have a Leitz controller, could that be the difference?Global Status 12-22-10
Global Performance 9-15-8
CAD++ 2015.1_SP7
I had 3.7mr3 loaded before and it work fine, I just never used it. What happen was I exported the settings in 3.5mr2 which I have been using all the time and had the toolbars and hot keys set the way I liked. So I imported the settings in the 3.7mr3 directory through the Setup Editor and I got this message now. I didn't think it was going to create this big of a problem.Global Status 12-22-10
CAD++ 2015.1_SP7
Without volcomp, your machine is probably less accurate then a pair of calipers. Make sure that even IF you get this message to go away, you verify that you have loaded the correct (or latest) file. Measure a couple of ball bar positions or larger gauge blocks. If you do NOT have the right volcomp, you will quickly find accuracy issues. And you would need a full re-cal.
I had a similar issue, found a file, copied it and the message went away. Came to find out it was an old file and my machine was not accurate anymore. Quite embrassing. Obviously.
Originally posted by Jan d. View PostWithout volcomp, your machine is probably less accurate then a pair of calipers. Make sure that even IF you get this message to go away, you verify that you have loaded the correct (or latest) file. Measure a couple of ball bar positions or larger gauge blocks. If you do NOT have the right volcomp, you will quickly find accuracy issues. And you would need a full re-cal.
Jan.
I have this happen occasionally and service techs told to me to shut down and restart the controller and the comp would relset itself.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by dwade View PostI have this happen occasionally and service techs told to me to shut down and restart the controller and the comp would relset itself.sigpic
Problem solved. Tech Support called and I had to copy the Leitz.dll file to a different folder, rename file to interfac.dll, paste it in the directory where the 3.7mr3 resides it will ask to overwrite existing file, say yes, problem solved. I did run a few ball bars to verify that it is checking fine. All is well. Thanks for the help.Global Status 12-22-10
CAD++ 2015.1_SP7
by scannerWhen I open PC-DMIS this is the message it displays "no volumetric compensation". Can you tell me what would cause this to pop up this morning?...
05-28-2008, 08:49 AM -
by jon_dav_ukCan anyone help.
Xcel 7-10-7
B3CLC controller
3.7MR3 and MM4 Emulator software
This machine has been running...-
06-04-2008, 12:40 PM -
by danumtdPCDMIS 2009 MR1 stopped functioning properly so we reloaded both the Windows XP ,and PCDIMIS I exported my Setting editor file and imported into the...
04-11-2014, 11:34 AM -
by GarDesoWe are attempting to install PCDMIS 2010 MR2 in a new PC running Windows 7. We are getting the message "Was the machine controller just reset?"...
03-03-2011, 11:19 AM -
by metrologo
Hi I wanted to understand if the software Pcdmis with controller Leitz, read volumetric compensation file only from the PC, because it gives me...
11-18-2010, 05:52 AM -
