Anyone done any GAGE R & R's with PCDMIS? What was your repeatability? Range?
GAGE R&R using PCDMIS
I've done both...
Customer requires GRR on all gages that is used on all key characteristics.
CMM is one - although not a full blown GRR (appraiser var is ignored or not evaluated), it does give an indication of accuracy + precision. I've no problem staying within the 10% requirement.
When you refer to a gage, do you mean fixtures or fuctional gage?
I've only performed on fixtures that will hold parts to check on CMM - again not a full blown GRR but comes close. It will show repeatability when removing and replacing parts on the holding fixture - also if it uses clamps then sequence becomes important. At least it will give me a sense of security using the fixture before it's fully employed and if needed modification, it will show that too.
I have not done GRR on functional gage (or any other gages) for that becomes an Attribute GRR - Go/NoGo... I've used the CMM to verify that it is made right though.
JRZPC-DMIS CAD++ 3.7 from 4.2 MR1
Yep, do them quite often. We don't have the GR&R option on Datapage, but I can do it using Datapage and Excel.
Pretty simple, but time consuming, the standard GR&R is 5 parts, 2 operators, 3 trials for each part, for a total of 30 checks. If you have the GR&R option of Datapage, you MUST use tracefields, one for each of the 3 'sections'. I use them even though we don't have the Datapage option, just in case something gets done in the wrong order, as long as the tracfields are correct, I can get it sorted back out.
Normal procedure is OP1 runs all his (her) checks, then OP2 does the same. Datapage will automatically sort them by the tracefields, so the actual order does not matter, as long as the tracefileds are correct.
TRACEFIELD1 = OPERATOR
TRACEFIELD2 = SAMPLE
TRACEFIELD3 = TRIALsigpic
by D-TrainI've been asked to do a Gage R&R project using the CMM as the gage, and a step gage as the control subject. We are trying to determine the R&R...
06-05-2017, 10:41 PM -
by CeephDoes anyone have any info on the 10-1-1 method for CMM's? 10 runs 1 part 1 operator. I am trying to determine which method is best.
02-13-2007, 12:51 PM -
by calbrittonI have two 2.25 class XXX setting gages. the ID of the Ring gage measures within .000010" of nominal but the Plug gage is measuring minus 000045"...
09-17-2016, 07:36 AM -
by dlewisIs there a way to configure PC-DMIS to setup any 3 gages (indifferent body positions) & run each program & print out a report, move on to the...
08-15-2007, 12:22 PM -
by DrEaMcMmhi,
i hav trimek CMM,the problem is that its measuring the 500mm gage block's nominal value as 500.012 and the actual or measured value is 500.022.can...-
12-06-2006, 12:04 PM -
