I am using PC-DMIS 3.6 on a MicroVal Manual CMM. I am having a problem setting up a work position on a part using a center hole as my main X-Y Zero and a bolt hole that is offset in both X & Y as a secondary datum. There are 3 bolt holes that are all not on the same bolt circle diameter and are all offset from the main center line. Can someone explain to me how to set up a work position with the center as my X-Y and also one of the bolt holes at pre-determined dimensions to set the part up as per the print. One other thing, one of my surfaces is at a 3 degree angle, so I am setting the part on a sine plate to have the bottom surface flat, so I can measure these holes properly. That surface is up and that is how the holes were machined.
Setting up an offset hole into a work position
What layout tech said. If the drawing is vague and you can't get interpretation help I'd do the whole shebang to the tightest toleranced features.
Everyone here will tell you that using 3.6 is a bad idea. There are even a few here that will tell you using a manual machine is a bad idea too. I am in the former camp but not the latter. I'm not sure how you use a manual machine in anything but manual mode but what do I know...........<internet bumper sticker goes here>
by Liambo734Have a part with 2 dowel holes. Bottom dowel hole is datum 'A'. Top dowel hole is dimensioned to Datum 'A' TP.001 MMC. Holes are not in line so i first...
12-09-2008, 03:55 PM -
by MJBolsterI have a cylinder like a hub of a wheel with spokes coming out all around at 30 degree intervals- like a wagon wheel- easy to visualize I hope. Okay-...
08-30-2007, 05:40 PM -
by cmmguyDoes anyone have the travel envelope for a ONE 7.10.7 relationship to the threaded holes in the table?
Specifically what I need is this:...-
09-06-2007, 11:45 PM -
by Mike_BI have a part, an exhaust manifold. The flat surface that attaches to the head is -A-. There is a flange 30 degrees to this face that has turbo mounting...
11-25-2014, 01:41 PM -
by Marc in SWWhat is the easiest way to skew a parallelogram. The part is about 8" wide and 15" long. This part has many holes and cutouts. There is not...
04-15-2010, 09:02 AM -
