Help with 3.7MR3
  • Help with 3.7MR3
    I have been working on getting 3.7MR3 to work on a Sheffield RS50 since the first part of August. I have asked for help from B/S about the problems that I have been experiencing. They ask for a debug file and you never hear from anyone. Can anyone help me in Forum Land. The biggest problem is the way the probe moves in 3.7MR3. It moves like a robot. It moves and stops before at proceeds to the next location. It does not move smoothly and it increases the time to run a part. I wrote a program in 3.5MR2 and it would run fine. I copy that program from 3.5 to 3.7 and it will not work correctly. If I do the opposite. Write the program in 3.7 back to 3.5 the program will not work correctly in 3.5MR3. Thank you for any suggestion.
    Have you tried downloading a fresh copy of 3.7MR3? The one you are trying to use may have gotten corrupted somehow. Did you make a copy of your 3.5 folder and install 3.7 into that? That is the proper way. Matt Hodeman has great steps on how to install a new version in the code section of the forum. HTH
    P.S. I am running both 3.5MR2 and 3.7MR3 and have not had the problems you describe. But I am on a B&S Xcel w/ Sharpe 32 controller.
      Gary, sorry to say, but I think you are SOL. Can you move on to 4.1? Not that that will solve your problem but it can't hurt right? The only reason I say this is I was working on a Sheffield just about a month ago, and it really didn't behave that well either. They were running 3.7MR3. I don't know of any remedies for you, sorry.
        I have heard this one before and I don't recall if there was a resolve. I think it was also on a Sheffield. Do I understand correctly that your machine is interpolating in "squares"?
        Craig
          Do you have fly mode turned on on the one machine and not the other?
            Wes
            Yes 3.5 and 3.7 are in different folders.
            Craig
            I think that is the way it acts 9interpolating in "squares".
            I guess I will move up to 4.1 and if it will work any better.
            Thanks Gary
              I have a Sheffeild Discovery II and fly mode does not work. I was told it depended on your controller. Sheffeild seems to have issues with PCDMIS. After upgrading to v3.7MR3, I now have to press the "AUTO" button on the RCU before every program starts. In v3.7MR1 & MR2 I did not have to do this. I hear v4.1 fixes these issues. It might fix yours?
