IJK, angle conversion?
  • IJK, angle conversion?
    I have the following, IJK values from a CAD model that PCDMIS spit out at me.
    I would like to know the angles relative to the current coordinate system for this feature though.
    There are so many ****ed options for the angle dimension I have no idea which one is what I want.
    Is there a easy whay to figure this out?
    I=-.914856
    J=.3778484
    K=.1423694
    Thanks again
    Mr. Comment
    SCIROCCO-NT 13-20-10
    I think your I and J is about a 66 degree angle.
    Do the sine and cosine of 66 degrees and see if it is close to your I and J vector readings.
      Try this....
      It is multiple pages so look at it all.
        Is it just me or is the 3d vector calculation in that spreadsheet wrong? You can't have 3 vectors of .707 - at least not in pc-dmis - if you type that in it changes them to 0.5773503. Someone once showed me a method for converting 3d vectors to angles and vice versa - unfortunately I don't remember what it was, but im sure it was more complicated than using the sine and cosine. I'm thinking that at least one of the very knowledgable people on this board must know it.
        Anyway, maybe you could create a point offset along that vector, then construct a 3d line from point to point and dimension the angle.
          Thanks
          Mr. Comment
            Vectors I, J and K are the cosine of the angles to the X, Y and Z axes respectively.
            Cos(X angle) = I
            Cos(Y angle) = J
            Cos(Z angle) = K
            To find the angle from the vector, just perform an inverse cosine of each (I, J and K).
            Stu
              I think that only works when the k component is equal to 0
              ijk are based on a unit of one(1) and when the k component is added it shortens the unit vector and changes the ij components. I will check this more, and if I am wrong or it is different than earlier stated then I will report that.
              All examples that I can find right now(including Richard Clarks) always represent k(Z) as zero.
                Another question on topic.
                Can you use a variable assigned to the IJK values for trig functions? Such as COS or TAN x V2. What would be the proper format for using this to calculate angles if you wanted to use the IJK values for this?
                Contura Calypso 5.4
                  Per the help file: "PC-DMIS will normalize the vector, making its length one unit. This vector is used for probe compensation."
                  Hence the 3x by 45 degrees turning into a solid row of .577's instead of .707's.
                  Amazing how 45 and 60 deg cosines are now engraved into memory.....
                  Tom H>
                    yes
                      A little off the question but when I run into a problem where I need all three vector directions I just rotate the part so the one direction' vector is zero. I just make a rotate align. I then calculate the sine / cosine plug them in the right location. You can then remove the rotation and PCDMIS will do all the nice math for you. just say yes to update when you remove the alignment.
                      Tolerance challenged ... Living in the world of unseen lines.
                      • InspectorJester
                        Line Angle to Feature
                        by InspectorJester
                        Hello all!
                        I have a cylindrical part mounted on a rotary table.
                        The print calls out 4 different angles on 4 subsequent sets of notches (each...
                        09-01-2017, 10:49 AM
                      • ARivard1
                        Ijk
                        by ARivard1
                        Hey there, it's your favorite newbe with a question that is hopefully easy to respond to. Is there a basic definition of I,J,K and its use? I know they...
                        06-25-2014, 02:09 PM
                      • claude
                        Vector direction
                        by claude
                        I am just learning PCDMIS and I have a question about the Vector directions. Is the IJK different in different working planes?
                        Thanks,...
                        08-05-2007, 10:59 PM
                      • Scott D. Haselden
                        IJ Vectors from Angles
                        by Scott D. Haselden
                        Hi guys,
                        I have heard about some of you folks that have an IJK Vector calculator, where you can plug in a 2d angle and it will give you the...
                        10-21-2020, 01:40 PM
                      • orion
                        tip angles
                        by orion
                        on my program i have
                        LOADPROBE/TOOL 6
                        TIP/T1A60B180, SHANK IJK 0,-0.866,0.5 ANGLE=180
                        04-12-2014, 05:42 AM
