If I am trying to get the run time of a program how do you "lock" an ASSIGNMENT?
  • If I am trying to get the run time of a program how do you "lock" an ASSIGNMENT?
    If I code.................at the start of the program:
    ASSIGN/START_TIME=(INT(SYSTEMTIME("H")*3600)+INT(SYSTEMTI ME("mm")*60)+INT(SYSTEMTIME("ss")))/60
    If I code.................at the end of the program:
    ASSIGN/END_TIME=(INT(SYSTEMTIME("H")*3600)+INT(SYSTEMTIME ("mm")*60)+INT(SYSTEMTIME("ss")))/60
    ASSIGN/PROGRAM_RUN_TIME=END_TIME-START_TIME
    This just equals 0 because the START_TIME and END_TIME keep going up and up and are equal..........so how do I lock them?
    Some code I wrote awhile ago
    [COLOR=#000000]$$ NO,**** CODE TO CALCULATE RUNTIME *****[/COLOR]$$ NO,**** OUTPUTS AS    HR:MN:SEC    *****
    $$ NO,**** ASSUME PROGRAM RUNS NO MORE THAN 2 DAYS *****
    $$ NO,***************************************************
                ASSIGN/START_HOUR = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("H")
                ASSIGN/START_MINUTE = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("m")
                ASSIGN/START_SECOND = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("s")
                ASSIGN/START_DAY = SYSTEMDATE("d")
                ASSIGN/START_MONTH = SYSTEMDATE("M")
                ASSIGN/START_YEAR = SYSTEMDATE("yyyy")
    $$ NO,****** YOUR PROGRAM CODE ******
                ASSIGN/END_DAY = SYSTEMDATE("d")
                ASSIGN/END_MONTH = SYSTEMDATE("M")
                ASSIGN/END_YEAR = SYSTEMDATE("yyyy")
                ASSIGN/END_HOUR = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("H")
                ASSIGN/END_MINUTE = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("m")
                ASSIGN/END_SECOND = [COLOR=#FF0000][B]SYSTEMTIME[/B][/COLOR]("s")
    $$ NO,****** FIRST *****
    $$ NO,****** TEST FOR SAME DAY *****
    $$ NO,****** ASSUMING ONLY 1 DAY AFTER START OF MEASUREMENT *****
                IF/START_DAY <> END_DAY
                ASSIGN/END_HOUR = END_HOUR+24
                END_IF/
    $$ NO,****** NEXT *****
    $$ NO,****** TEST FOR SECONDS *****
                IF/END_SECOND >= START_SECOND
        ASSIGN/SECONDS_RUN = (END_SECOND-START_SECOND)
                GOTO/L1
                END_IF/
                IF/END_SECOND < START_SECOND
                ASSIGN/END_SECOND = END_SECOND+60
                ASSIGN/END_MINUTE = END_MINUTE-1
        GOTO/L1
                END_IF/
    L1         =LABEL/
    $$ NO,****** TEST FOR MINUTES *****
                IF/END_MINUTE >= START_MINUTE
                ASSIGN/MINUTES_RUN = (END_MINUTE-START_MINUTE)
                GOTO/L2
                END_IF/
                IF/END_MINUTE < START_MINUTE
                ASSIGN/END_MINUTE = END_MINUTE+60
                ASSIGN/END_HOUR = END_HOUR-1
                ASSIGN/HOURS_RUN = (END_HOUR-START_HOUR)
                 END_IF/
    L2         =LABEL/
                ASSIGN/RUN_TIME = (HOURS_RUN+":"+MINUTES_RUN+":"+SECONDS_RUN)
                COMMENT/OPER,YES,***************************************************
                                ,"PROGRAM RUNTIME ==> " +RUN_TIME
    feel free to change it to suit your needs.
                  END_IF/
                  GOTO/L1
                  END_IF/
          GOTO/L1
                  END_IF/
      L1         =LABEL/
                  GOTO/L2
                  END_IF/
                   END_IF/
      L2         =LABEL/
      Many thanks dph51 - I'll try that
        The code from DPH51 is good, but I am not sure there is anything wrong with your code either. Please elaborate. What do you mean they keep going up and up? When I use your code in my program, it works fine. About how long does it take to run the section between these 2 statements?
        There was an issue long ago, where you could place start and end time statements around the program, and the would report the same. That was because the processor application would look at the two and believe they did not depend on anything else in the program so it would run those without waiting. We found that you need to at least add a dimension callout before the End calculation, it would be forced to wait before performing that calculation. That was long ago, and I believe it has since changed. I am interested to know what you are experiencing.
          I believe the program should take about 30 mins or so.
          I've got about 2 dozen toleranced dimensions.
          If I hover the cursor over my original versions of the START and END statements I can see the numbers going up and up and up - and that they're the exact same....................like it's giving me "what time is it now" instead of what time was it when these lines were ran.
            Hovering seems to evaluate the right hand expression, not fetching the left hand variable. What is the result of PROGRAM_RUN_TIME at the end of run (COMMENT/OPERATOR ...).
              If you hover over them in your program, they will equal "0". But it is when you execute your program that it should take in effect.
              Add this to your program after the ASSIGN/PROGRAM_RUN_TIME=END_TIME-START_TIME
              COMMENT/REPT,
                          "TOTAL PROGRAM RUNTIME (IN DECIMAL MINUTES): "+PROGRAM_RUN_TIME
                COMMENT/REPT,
                Yes - that's now working correctly.
                As suggested you need to run the program to it's conclusion to get the "locked" assignment values.
                Many thanks to all who have replied to my OP.
