We are in the process of testing 4.1, mainly for ppap reasons. Is there a way to dimension true position and have it report the -x- and -y- values without dimensioning them seperately? It is a pain to put it in twice when in 3.7 it puts it all on the report.
4.1 Dimensioning
The XYZ for each of the features should already be in your True Position Dimension's summary. Just below the Datum Shift section.
Since you probably arent seeing this already, check to see if your using the TextOnly.rpt template? It would say at the top of the Report Edit window which template is being used. You can change this by clicking on a different template in the Report Tool bar.
Another option would be to use the Legacy Dimensions instead of the new style dimensions, however you should expect to see a difference in the results, because TP isnt calculated the same way between the two styles of Dimensions.Mr. Comment
SCIROCCO-NT 13-20-10
When you find a solution to this problem, please let me know! I have the same issue.
I think, though, that you could fix this by going into the "rules" in the Report. Add XYZ to the rules.
However, I have found that any changes you make to TEXTONLY.RTP may cause your TP call labels to completely disappear. Hexagon PR number 24410. I heard this may be fixed in V4.1B but for sure V4.2.
by turdbisketI believe I have created all of the features i need and have everything set up correctly. When i am in the True Position dialog box, I have datums created...
01-08-2007, 08:31 AM -
by Jonde1In my most recent program I have reported dimensions using the USE LEGACY DIMENSIONS feature. we have reported the true position of 26 holes in a flange...
01-15-2015, 08:48 AM -
by rerun_livesWho's using 4.1 now? What's your quick eval?
08-24-2006, 03:56 PM -
by racerx00hi,
I am starting to play around with v4.2 and was wondering how you get the dimensions into the report template. seems a little confusing...-
03-05-2008, 12:11 PM -
by rerun_livesDoes anyone have a Report template for 4.2 that reports the number dimensions measured and the number out of tolerance at the end of the report that they...
09-12-2007, 12:00 PM -
