I'm having a reoccuring problem of PCDMIS getting caught in an internal loop or something. Scenario: I Complete programming features, I complete dimensioning of those features, when I go back to edit a feature and save the F9 window PCDMIS will display a message at the bottom that it is loading the report and shows it's progress bar. Even after the progress bar reaches 100%, it will reset and start counting the progress from 0%. This will repeat several times. Sometimes it will recover and let you continue, sometimes it will not and just keeps loooping. Looking at TaskManager, the memory usage continues to climb during this looping. Anyone else experienced this or have any ideas how to either stop it all together or to break out it's looping? Thanks.
Locking up V4.1 during edits?
I had the same issue and it was suggested that I turn the printer option off until the editing was done. I have only tried it on one program since this suggestion but it did seem to work.
Give it a go and if it works, thanks to James Mann.sigpic
PCDMIS 4.1, 3.5mr2,
by Bass AssasinHas anyone ever had this happen. I did a couple perpendicularity checks . So in a loop of 32 it screws up every third one and is off by .060" when...
07-24-2007, 04:36 PM -
I was wondering if anyone else is having this happen. After picking a point off of CAD model and creating the feature, when I go back to the command screen...
07-30-2007, 03:10 PM -
by Joe.ReillySo I have 100 small squares with 4 holes on the corners, I am set up to run 3 then the program ends.
I want to just replace the parts...-
09-25-2013, 01:13 PM -
by CaemgenWhy when I run a program all the way through is it adding a bracketted number after many (not all) of the features?
I am not looping or...-
03-24-2014, 07:07 PM -
by williamI havent used looping in any of my programs. I came across one today written by the previous CMM guru which used a loop to measure a feature set that...
02-26-2015, 08:49 PM -
