Freeform Scan Does not Scan continuosly it takes points (I have a SP 25 analog Probe)
  • Freeform Scan Does not Scan continuosly it takes points (I have a SP 25 analog Probe)
    How can I make the freeform to scan continuously I am using a CAD File and it does follow the pad that I choose on the CAD is just that does not use the continuous scan it probe/touch the pad. (Any other basic scan works fine) (PcDmis 2014 CAD++ SP25) Thanks in advance.
    Try something like relearn instead of defined or master (I'm not at the cmm...)
      I'd imagine freeform has to be set as 'defined'.
      Applications Engineer
      Hexagon UK
        +1, Ninja !
        After creating points on the cad, you need to "calculate" the way of scan, then it should scan and not go ttp...
