We just upgraded? to 3.7 MR3 (about a week ago) and now (last two days) I am getting a series of Serial Jogbox Errors (...sent illegal character, ...Timeout, ...did not respond in time). By the time the "...did not respond in time" message comes up, it is flashing incessantly on the screen, the lights on the jogbox are flashing at the same rate, and PCDMIS locks up completely. I have to Ctrl-Alt-Del to close it. I can only run PCDMIS for about 3 minutes before all of this goes down. If anyone has dealt with this before, or knows how to cure it, I would be ever so appreciative. I left a message w/ tech support, but...
You need a new jogbox. Something is astray inside your jogbox right now. First, take the back off, and re-seat all the the connections - the joystick, e-stop, and big blue connector.
I just went thru all of this a couple of weeks ago. It would work for a while, then wouldn't. A new reman $1500. jog box seems like it did the trick. Talk to Terry Kennedy at B&S parts about it.sigpic Life is not a journey to the grave with the intention of arriving safely, but rather a skid in broadside, totally worn, proclaiming WOW What a ride!
Allright - figured it out (just in case anyone else has the same problem down the road). We've had A LOT of work done in recent weeks to this machine. It looks like the last service tech to disconnect the jogbox from the controller forgot to tighten the screws back up before they put the cover back on the unit. Four plugs were either disconnected or loosened to the point of falling off (the X, Y and Z motor inputs and another unmarked one). It was as simple as plugging them in good, tightening the screws and putting the cover back on. Of course I didn't notice that they were off until I was installing our new jogbox that we were told we needed (by B&S). Duh.
by rtlawlorSo I have been having issues with my Brown & Sharpe 7107 (Serial #: 0702-1416) JogBox sometimes not turning on right away, then wait a minute or two...
09-28-2016, 03:01 PM -
by MidwestWhile working on a program yesterday I pushed the Enable button on the jogbox and the probe started moving forward. I hadn't even touched the joystick....
07-25-2013, 09:19 AM -
The cable for my jogbox is not long enough (in my opinion).
I tried to plug it in through like a 3ft USB extender, and then I couldn't connect with...-
05-17-2018, 09:34 AM -
by frazzRecently our B&S Global running 2010MR1 started to act up. I do not think it is software related. The symptoms: The probe crashes or there is an...
11-07-2011, 09:19 PM -
by Hortiz85Good morning,
Please let me start by telling you how I have already tried to fix this issue; I have tried holding enable + the three directional...-
08-23-2019, 07:34 AM -
