v4.1 Global Image 9128 no probe change rack. When running a program in Operator Mode the software does not prompt the normal change probe dialogue box when a probe change occurs in the program. It just keeps running and crashes. In full Edit Mode the same program presents the normal "Load Probe 1X20" with OK or Cancel option buttons. It does not do this in Operator Mode. Any thoughts on the cause or remedy?
v4.1 Operator Mode Probe Change Prompt
Have you set up MARKED SETS? It may be an issue with no marked sets created? Don't forget when making marked sets to check off the box for "LOCK MARKED SETS" under PREFERENCES>SETUP>LOCK MARKED SETS check box. Otherwise, when you open up the marked sets window and inadvertently uncheck something you won't know you did it. The method I described at least requires some thought put into making changes.sigpic
by AguayoI know I read something about lock Mark set in this forum,but I can't find it
in the set-up options there is a key to lock mark sets to prevent...-
06-23-2006, 10:51 AM -
by pjleitnerI'm getting the File Manager window when I open in Operator Mode, instead of the Marked Sets window. After you navigate and open a program, the Marked...
10-25-2006, 03:01 PM -
by Jonathan SI opened operator mode for the first time today to see how it looks and operates. It's time to start writing programs for others to run so they can do...
07-29-2008, 09:38 AM -
I am doing some programming on an old system with PC DMIS 2009. I have written my programs, but the process I have to follow is to use marked sets to...
09-24-2019, 10:01 PM -
V:2013 MR1 - We are NOT using Operator Mode.
How can I get the Marked Sets Window to open automatically when the program is opened. I want this...-
11-24-2014, 09:06 PM -
