Can anyone help me calculate the correct approach vectors for a surface that is in an angled bore. The bore angle is 26 degrees to my leveling datum and I am using a tip angle of A60 B-180. The surface is not on the cad model so I can't get the vectors that way. I used to know how to do this but it has been since my mm4 days that I last used it.
Help with Vector Calculation
That is great but I guess I was not clear enough in my post. I am not measuring a circle but a machined step(plane) in the bore that is sitting at a 26 degree angle to my datum surface. I need the normal vectors for the surface that is not on my cad model.
Vectors can be calculated very easily with any calculator with trig functions.
You just need to understand that the 2D vector is the sine and cosine of the angle. For example, the vectors for 30deg are 0.5 & 0.8660524. The axis with greater movement is assigned the larger vector because that axis must move farther to approach/retract normal to the surface.
HTH
Edit: Craiger only gave you the cosine. You need sine also - 0.4383711v2013 MR1, v2015.1
B&S Global 544, 555
Mitutoyo A504 w/PC-DMIS
Since 1994
(Advice from my dad.)
I couldn't remember if it was sin, cos or -cos. I actually got the number you gave me I just didn't want to plug it in my CMM without someone verifying I was correct.
DUH PCDMIS will calculate for you. I just put 26 in for one of the vectors and it calculated the others.
Originally posted by JamesMannes
TKsigpicHave a homebrew
Originally posted by CeephDUH PCDMIS will calculate for you. I just put 26 in for one of the vectors and it calculated the others.
Cool - I didn't know that worked. I always rotate to any angle and use 0,0,1 0,1,0 or 1,0,0. Just laziness on my part I guess.sigpic
Originally posted by CeephThat is great but I guess I was not clear enough in my post. I am not measuring a circle but a machined step(plane) in the bore that is sitting at a 26 degree angle to my datum surface. I need the normal vectors for the surface that is not on my cad model.
I know I'm late to the party but I was off yesterday.
This is what I would do. I would re-align to your bore. For example, level the bore to z-plus and set the x and y orgins on the bore. Then, your plane's vector will be 0,0,1 and it's location will be 0,0,z. After the plane, recall your previous alignment. This way, if the cylinder is off of location or orientation just a bit you will still get good hits. Also, you can get your probe to take hits .005 or less off of the cylinder wall.
I do this all the time. It works wonderfully!
by RUSTY COGCan somebody please explain why the surface and angle vectors are different in 4.3 than 3.7 mr3? I have read the help files, and thought I understood...
09-10-2008, 01:08 PM -
by inspector2122009MR1 is getting the surface vector for edge points backwards. I have to click Flip Vector for everyone. I am programming offline. I anyone else seeing...
01-08-2010, 11:54 AM -
by Mike_BI know my CMM can calculate vectors using 3 points, forming a plane, etc.
I also know how to extract the vector using "read machine"...-
08-19-2015, 04:09 PM -
by Vikingroovinif I am taking a hit straight up in the +Z with this probe angle what should my Vector be?
TIP/T1A60B180, SHANKIJK=0.0037, -0.8655, 0.5009,...-
10-19-2015, 01:14 PM -
In relation to my post a few posts down........Rob Knoerlein-circular part with 8 legs.. If I am rotated 90/135 and tracking to hit a feature ( in this...
07-08-2008, 01:28 PM -
